Originally Posted by MaineStreamer
The new Blue Beret magazine has an article on winterizing. For the antifreeze method, it says nothing about draining the antifreeze out as part of winterizing.
On page 39 of my November 2019 WBCCI Blue Beret (digital copy) the article says in section 8:
"Once done, drain the whole system and capture the antifreeze by draining it from the low points and back into the gallon jugs. Blow out the lines again to get as much of the antifreeze out as you can. Clean up all the residual antifreeze, pour some of the captured antifreeze down the drains and the rest into the gray and black holding tanks."
The next paragraph goes on to say:
"You could also just leave the antifreeze in place for the winter and purge the lines with water in the spring."
It is your choice to leave the antifreeze in or not, however, leaving it in does not add any additional protection.
There are advantages to draining it out immediately.
1. makes for a quicker de-winterization process in the spring, and
2. the drained antifreeze can be used in the holding tanks - providing added protection the blade drain valves.
Winterize WBCCI 2019-10.pdf
