Old 10-28-2013, 11:10 AM   #15
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Originally Posted by myropa View Post
I ended up buying a new 6 gallon portable compressor so I can maintain all the tires while on the road. No oiled tools are used with this one. But I use a disposable water/oil trap on the business end any way. Can you say "belt and suspenders?"
Oh and now I am friends with the neighbors with RVs. ;-)
What is the brand and source for the trap filters you use?
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 10-28-2013, 12:20 PM   #16
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Be sure to get a coalescing filter:
"Standard nominal five micron inline filters cannot remove
submicronic contaminants as required in critical
applications. The lowest particle removal limit for these
general purpose filters is 2 µm. Eighty percent of aerosol
contaminants are under 2 µm in size. Coalescing filters,
however, are specifically designed to remove submicronic
oil, water and solid contamination from compressed air.
Standard graded-porosity coalescing filters remove over
99.97% of all aerosols in the 0.3 to 0.6 µm range. In
addition, these filters are over 99.98% effective at
removing all aerosols and solid particles larger than 0.3 µm.
Thus, oil aerosols at a 20 ppm contamination level are
reduced to a 0.004 ppm concentration – acceptable for
virtually all pneumatic applications."
Great website on the topic:
http://teamtechnical.com/html/Parker...Coalescing.pdf
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Fresh Water Tank and City Water ??? tr0y Fresh Water Systems 3 08-29-2011 04:49 AM
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 07:02 PM
Tepid water, lots of air bubbles Spot Water Heaters, Filters & Pumps 23 06-16-2011 08:35 AM
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 09:52 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
