Old 12-16-2005, 07:38 PM   #1
mtnman's Avatar
Collettsville , North Carolina
PVC to Qest
Hey, I have a drain valve stuck and needs to be replaced. I need one connection of PVC to a drain line 4 inches. Can I glue a PVC coupling to the Qest line and start there rather than cutting out $20 worth of Qest fittings?
mtnman
mtnman is offline   Reply With Quote
Old 12-16-2005, 08:33 PM   #2
campcollector's Avatar
2003 19' Bambi
Lincoln City , Oregon
Images: 21
glue
If the question is gluing pvc to quest,then no . Qeust pex is a polybutelene plastic and won't bond to PVC (Poly vinyl chloride).
quest pex is mechanically crimped to a brass transition fitting that provides a pvc coupler if going from Quest to PVC. If you go to a plumbing supply place you may be able to cut the crimp ring, heat the quest with a heat gun and pull the bad valve out if there is enough slack in the pipe. The plumbing place will usually loan out the crimping tool for a short period of time so you can re-crimp it. Without seeing exactly where your working and the way its plumbed this is all the advice I can give. I would advise staying with quest or PEX over PVC in a trailer. PVC doesn't handle vibrations and freezing as well as the quest. Also quest makes a comprestion fitting that fits over the pipe and a nut locks it down, there may be a transition fitting like this and you would not have to use special tools. Good luck
"No good dent goes unpunished."
campcollector is offline   Reply With Quote
PVC piping Devoman Fresh Water Systems 8 09-30-2005 07:46 PM
PVC Valves davespann Mechanics Corner - Engines, Transmission & More... 1 03-02-2003 08:43 PM
Filling fresh water tank- overflow normal? John Fresh Water Systems 20 02-23-2003 12:43 PM
Two PVC pipes? John Fresh Water Systems 11 12-06-2002 04:59 PM
PVC waterlines? buckmaster Fresh Water Systems 2 11-09-2002 06:43 PM
