Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 09-11-2008, 05:51 PM   #21
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
That is true.. I'm doing a little at a time so I can still use it so it would be hard for me too.. But I am replaceing some of the copper as i go... Have a bunch left over from a job.... so save a little $$$..
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-11-2008, 09:17 PM   #22
64TrotterAtl's Avatar
1964 19' Globetrotter
Decatur , Georgia
Sergei,
Thanks for the pics. I saw these fittings today at a Lowe's. Thanks to everyone for their opinions.
My blog is Restoration of 1964 Airstream Globe Trotter
Andrew
64TrotterAtl is offline   Reply With Quote
Old 09-12-2008, 03:49 PM   #23
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
Andrew,
Just when you've heard enough. I agree PEX is the way to go. I'd also suggest considering stainless flex hoses in strategic locations. The water heater becomes easy to drain and bypass for winterization when you pipe the last 18 - 24" with flex hoses. By the way, I used the quick clips to avoid buying mulitiple tools for crimping. Ended up, it was all in one size tubing anyway. And, the factory uses white for cold and red for hot, if you want to take it that far.
Best of luck,
Roy
64airstream is offline   Reply With Quote
Old 09-12-2008, 06:48 PM   #24
1994 30' Excella
Mississauga , Ontario
I have seen a product here in Canada called PexAlPex which is two layers of Pex with a layer of Aluminum sandwiched in between. The beauty of this product is that you can bend it to whatever shape you want and it will stay there. Therefore you can form a single piece of pipe from one location to the other without adding any fittings what so ever.
That means less chances for joint failures.
My own trailer(a 94) has factory installed pex with copper 90's etc. crimp connected.
Amazing how many fittings there are.
Still I have not had any failures.
Al
Old 09-13-2008, 04:24 AM   #25
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Al,
They have that here in the US too. The product seems to be made just for a guy named Al.
I thought about using it but I'm concerned that the Aluminum layer (which is included to prevent oxygen absorption) would split when frozen.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
https://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 09-13-2008, 08:53 AM   #26
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
I replaced my 67's copper with red and blue pex with Shark-bite fittings.
So far, so good...
Fittings are a bit pricey..
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
PEX vs. PVC - Which on for fresh water muddy_hollow Fresh Water Systems 8 07-11-2008 06:51 PM
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
Keep the copper or replace with PEX kdenault Fresh Water Systems 16 03-13-2007 09:37 PM
Cost: PEX vs Copper TomW Fresh Water Systems 5 04-13-2006 06:15 AM
PVC to Qest mtnman Plumbing - Systems & Fixtures 1 12-16-2005 08:33 PM
