Old 08-20-2013, 10:54 AM   #1
PhiDor's Avatar
2007 34' Classic S/O
The Villages , Florida
Unhappy PUR Filter leaking
I have a PUR #210 water filter under the sink. It takes one of those blue cartridges. I went to replace the filter the other day and the case was screwed on so tight, I had to take the filter off the wall and disconnect the hoses so I could get at it with the supplied wrench. Now that it is back together, it leaks like mad probably around the water out to the faucet connection.
It doesn't seem that the hose is tightly connected at the filter, but I can't get it any tighter.
Can someone help me with this problem?
Phil & Doris Drugge
[COLOR="Red"]WBCCI #4941
"Jerry and our Amazing Dream Stream"
PhiDor is offline   Reply With Quote
Old 08-20-2013, 11:15 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by PhiDor View Post
I have a PUR #210 water filter under the sink. It takes oone of those blue cartridges. I went to repalce the filter the other day and the case was scrwed on so tight, I had to take the filter off the wall and disconnect the hoses so I could get at it with the supplied wrench. Now that it is back together, it leaks like mad probably around the water out to the faucet connection.
Might be able to offer a suggestion if we could see how the lines are attached to the filter cannister. Pictures?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-20-2013, 11:29 AM   #3
dznf0g's Avatar
Oswego , Illinois
I've not had my lines off, but I think there is an o ring on the fitting...as well as the cartridge housing. I have had crud get into the o ring area and cause a leak. I'd clean and lubricate all the o rings with 100% food grade plumbers silicone.
-Rich-
Old 08-20-2013, 12:08 PM   #4
PhiDor's Avatar
I don't have any pics, but I might get over to the trailer and take a couple. Thanks for the reply.
Phil & Doris Drugge
Old 08-20-2013, 12:11 PM   #5
PhiDor's Avatar
I did notice a small O ring that may have been inside the hose connection lying on the floor. I put it into the connection, but it may not be right. You can't see into that. What a mess!!
That connection just doesn't seem right. Are there supposed to be 2 of those wire clips on the connecton? Mine has one.
Phil & Doris Drugge
Old 08-20-2013, 12:40 PM   #6
dznf0g's Avatar
Oswego , Illinois
I'll go look....stand by.
-Rich-
Old 08-20-2013, 12:54 PM   #7
dznf0g's Avatar
Oswego , Illinois
Both lines have a single clip which holds the black collar on and retains the line. Both lines turn freely within the top housing, which tells me it is an o-ring seal. No tightening capable. Just remove the clip, collar and inspect/clean/lube the o-ring. Replace if nicked.
-Rich-
Old 08-20-2013, 03:06 PM   #8
PhiDor's Avatar
Wink Still at it with Leak
Boy is it hot in the trailer! I think I lost 20 pounds in 10 minutes.
I greased everything up, but that didn't help. Well, it may have but it still leaks. So sitting here in my A/C den, I have the hose and the blue part on my table. It looks like the hose may be missing a part. If you look in each end of your hose, I think you'll find a white washer of some sort, like a flat washer except on edge like a piece of pipe. My hose only has one and I bet that has gone somewhere when I disconnected the hose the other day. I searched, but can't find it. If I take the black clips and spring clip off, I bet that will come right out. Then all I have to do is find the place in America or China or wherever they have a bunch of those and get one.
If one of you folks out there is willing to look at both ends of your connection to verify there is a white washer on each end, I'll be very happy and will buy you the beverage of your choice when we meet.
Phil & Doris Drugge
Old 08-20-2013, 03:16 PM   #9
PhiDor's Avatar
Arrow Leak
I have the little white devil in my hand, well in my pocket. As I thought, when the clips came off it came right out. BUT, it's not just a simple little thing, but has bumps and notches on it. 5/16 id and 7/16 od.
Does anyone know a washer salesman in China?
to be continued....
Phil & Doris Drugge
Old 08-20-2013, 03:25 PM   #10
dznf0g's Avatar
Oswego , Illinois
I'm having trouble referencing the items you are talking about. Are you talking about the filter end of both lines? Which one is missing...the fat supply side...or the filtered small delivery side? It is leaking at the filter, right? Which line?
-Rich-
Old 08-20-2013, 03:29 PM   #11
dznf0g's Avatar
Oswego , Illinois
Looks like it may be part of the hose assembly, if I understand you correctly.
Model_210.pdf
-Rich-
Old 08-20-2013, 03:30 PM   #12
PhiDor's Avatar
Hose
It's the larger of the two hoses.
Both ends are the same.
Phil & Doris Drugge
Old 08-20-2013, 03:34 PM   #13
dznf0g's Avatar
Oswego , Illinois
Or contact Delta (or Moen) but in '07 I think your faucets are Delta. Mine is. They are open till 10pm your time
Contact Us : Delta Faucet
-Rich-
Old 08-20-2013, 04:45 PM   #14
PhiDor's Avatar
Thumbs up Success!
I called Delta, explained my problem, and they are sending me a whole new hose for zip!
I'll let you know how I make out in 7-10 business days.
Thanks a lot for the assistance. I'll buy you that beverage!!
Phil
Phil & Doris Drugge
