Old 11-13-2013, 07:09 PM   #1
2005 19' International CCD
Roswell , Georgia
pump sounds/low pressure/culprit
On a recent trip, we had an issue where the pump sounded funny and we really couldn't get enough water pressure from the pump for it to be worthwhile. Last night, while winterizing, I believe we found the culprit (see pic). We could not pump antifreeze until we removed this. After that, all was good.
What is this item and what is the recommended maintenance regime?
joelbert is offline   Reply With Quote
Old 11-13-2013, 08:42 PM   #2
aftermath's Avatar
Spokane , Washington
I believe that thing is the pre pump filter. It is there to prevent damage to your pump. I don't know what you meant by "we removed this" but if that worked perhaps you need to clean the filter.
I took mine off once to clean it but it really didn't need any cleaning.
aftermath is offline   Reply With Quote
Old 11-13-2013, 08:46 PM   #3
1974 Argosy 20
Kooskia , Idaho
It is the pump filter, and is required by the pump manufacture. If it changed your pressure situation, it will need to be cleaned and/or replaced. They can be taken apart to clean.
Old 11-13-2013, 09:17 PM   #4
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Could be sucking air in through the filter. Check to see if the o ring is in good shape and seated correctly.
thehandyman is offline   Reply With Quote
Old 11-14-2013, 04:44 AM   #5
Roswell , Georgia
Thanks!
Ok, we will disassemble it, inspect it and clean it. In the spring, when we put it back on, we will see if it is still an issue.
If so, we will find out how to replace it. Anyone have a part number or link to purchase a new one?
