Old 01-08-2019, 09:19 PM   #1
honi soit qui mal y pense
Robere's Avatar
2015 23' FB Flying Cloud
Bend , Oregon
Pump cycles after all faucets off.
Two nights before departing central Oregon I failed to leave the furnace on and yes the plumbing froze. Now I have an air leak? that manifests itself as an intermittent pump cycle well after all the faucets are off. So have you experienced this issue and if so where did you locate the cracked plastic connector? Or was it something else? Not a trip breaker but could be annoying over the next few months as we travel the SW. Thank you for your thoughts.
Robere (aka Pepe) & Jacqueline (aka Gigi)
with pups Ella (the miniature poodle)
and Tibet (the Lhasa Apso)
2016 Chev Silverado LT Crew 4x4
Robere is offline   Reply With Quote
Old 01-08-2019, 09:33 PM   #2
1971 27' Overlander
Kansas City , Kansas
Os it an air leak or a leak?
I had a very small leak under my faucet. The pump would cycle on about every 2 hours. If the leak wasn't somewhere obvious, it would have been quite hard to find as it only dripped about 4 drips in an hour. That was enough to start the pump.
Shermy1987 is offline   Reply With Quote
Old 01-08-2019, 09:44 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yes I've had similar...'cept it WAS a deal breaker, AT 5AM
The pump is now on only when water is needed, off at night and whenever the trailer has no humans in it.🥴
As noted if it's a small leak and only cycles once in a while, use the pump as on demand, and search when it's more convenient.👍
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 01-09-2019, 07:45 PM   #4
Robere's Avatar
Bend , Oregon
No visible leak anywhere so suspect a small crack in a plastic fitting. Thanks Bob for your insight. We are “on demand” for now when not on shore connection.
Old 01-09-2019, 07:47 PM   #5
Robere's Avatar
Bend , Oregon
Btw: the pump cycles about every 10 seconds.
Old 01-09-2019, 07:50 PM   #6
Lily&Me's Avatar
Normal , Illinois
Make sure the caps to your water tanks are on tightly, in case that is the source of the pressurization, and try to find your leak as you don’t want water accumulating anywhere.
Be sure to check the back of the toilet. I have just had the water feed on mine replaced.
Maggie
Old 01-09-2019, 07:57 PM   #7
mefly2's Avatar
2015 25' FB Eddie Bauer
Can you see any water leaking from underneath ...?
Old 01-09-2019, 08:03 PM   #8
2019 30' International
Pennsylvania , Pennsylvania
Sounds like you have a leak, not an air leak, a water leak. You might want to try and trace all your plumbing to see where the leak is. Check the pump fittings, outside shower head. Take the time to look it over. Maybe put the system under pressure and look/listen both in cabinets, and outside to try and track it down.
majorairhead is offline   Reply With Quote
Old 01-09-2019, 08:16 PM   #9
👍Yep...look for the drips, not here...in the AS 😂
Amanamus
"Tahawus"
Old 01-09-2019, 08:21 PM   #10
2018 23' Flying Cloud
Savoy , Texas
Our water pumps check valve was leaking which caused a pressure drop. Then the pump would start. Replaced the pump. That fixed the problem.
SpinWhite is offline   Reply With Quote
Old 01-09-2019, 08:22 PM   #11
OP says his is cycling every 10 seconds, my bet is that's not a check valve.
Old 01-09-2019, 08:52 PM   #12
Robere's Avatar
Bend , Oregon
When I hook up shore water to the Airstream with a full tank of on-board water in the tank the water is back flushing into the on-board tank system and overflowing the tank at the fill point. Is this an indicator of where my problem might be, possibly a check valve?
Old 01-09-2019, 09:01 PM   #13
Robere's Avatar
Bend , Oregon
This is a new symptom as this is our first night on shore water. My apology as I am using my phone instead of a computer.
Old 01-09-2019, 09:13 PM   #14
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
This is definitely an indication that the check valve in the water pump is not working. It is most likely the reason the pump is cycling. It might be time for a new pump.
Richard
Water Pump Rapidly Cycles on/off when in use Mellinkat Water Heaters, Filters & Pumps 2 06-24-2015 07:04 AM
bathroom faucets don't work after de-winterizing Steve97365 Fresh Water Systems 3 05-06-2013 12:39 AM
Shur-flo water pump cycles on and off steverino Plumbing - Systems & Fixtures 11 05-29-2011 02:51 PM
Pls explain the different cycles of a New Penguin Heat Pump! FullTimin2HI Furnaces, Heaters, Fireplaces & Air Conditioning 5 03-16-2011 08:09 AM
Water Pump cycles often Guitars Water Heaters, Filters & Pumps 3 11-19-2002 08:04 PM
