Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 05-08-2008, 06:14 PM   #1
twiggy137
Profile:  1973 23' Safari
northfield , Massachusetts
pressure relief valve
replumbing 73 safari rearbath combo i thinks it's a pressure relief valve. valve goes to a dump though the floor also ties to drains for hot and cold lines. do i need to have relief valve. thanks Don
twiggy137 is offline   Reply With Quote
Old 05-08-2008, 06:29 PM   #2
CharlieE
Profile:  1990 34' Excella
Parsonsfield, , Maine
Twiggy,
When water is heated it expands. If the high limit gas burner burner cut off malfunctions and the water heats to temperature boiling water and even steam, the pressure in your hot water lines to bathroom and kitchen sink and even the cold water lines feeding the hot water heater could rupter at the weakest point and spray hot water or steam and scald anyone near the rupture. Pressure valves are required by code. Don't remove it or your safety could be in peril.
Charlie E
CharlieE is offline   Reply With Quote
Old 05-08-2008, 06:37 PM   #3
CharlieE
Twiggy, Forgot. The releif valve is mounted on your hot water heater. If you see a valve in your plumbing on the copper tubing behind the toilet soldered into the copper pipe you're probably looking at the pressure regulator valve that doesn't allow incoming street water pressure to exceed what your plumbing system can stand. Also in series with the pressure regulator I believe you'll see another brass gadget on the pipe that is a check valve that prevents your pump from sending your trailer water back out on your hook-up hose into nearby trailers or the campground water or city water source. Charlie E.
Old 05-08-2008, 06:41 PM   #4
CharlieE
Twiggy,
Northfirld, Mass. Mt. Herman and Northfield Academy. Is the Connecticut River still in Flood Stage? Charlie E.
Old 05-08-2008, 06:48 PM   #5
twiggy137
thanks charlieE yes the relief valve is under the sink in the rear bath. local RV dealer said i didn't need it,but i will install new pressure relief in same place.thanks again.
Old 05-08-2008, 06:50 PM   #6
twiggy137
charlieE yes the river still up.I live up behind the northfield campus, rustic ridge
Old 05-08-2008, 07:02 PM   #7
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
You described a "high pressure pop off valve."
Should you hook up to a water supply system, like you have today in many trailer parks, and don't have that valve, you will take the chance of blowing a water line.
Please try to remember, Airstream didn't use that valve just to be nice.
That valve has a definite and very useful purpose.
Some people may argue that if you use a water pressure regulator at the hookup faucet, then you don't need the pop off valve.
That is true, but don't ever forget to use the regulator.
Pop off valves are cheap.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 05-12-2008, 07:55 PM   #8
ddivell
Profile:  2001 27' Safari
Plattsville , Ontario
Hi all I have a 2001 Safari and I just tried to test for water line presure by hooking up to city line I can't get full presure on the kitchen sink and low presure in the washroom, I looked at the manuel I cant see any other valve to turn on or off has anyone had this problem
ddivell is offline   Reply With Quote
Old 05-12-2008, 10:17 PM   #9
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
The first thing I would do is remove the screens at the faucet outlets and re-try. Your screens may be plugged.
Does the toilet flush adequately?
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 05-13-2008, 04:41 AM   #10
ddivell
Update 635 am The toilet flushes fine plenty of presure, I will try the cleaning of the screens, the hand held rinse spray is only useing a few of the holes same in the shower, I noticed when I open and closed the bypass valve to the heater the hot line had a gush sound but the cold line did not make the same gush, is it possible the cold water valve is stuck? when I open the main drian valve , plenty of water thier, so that is past the city water check valve
Old 05-13-2008, 08:20 AM   #11
Chuck
Chuck's Avatar
Images: 99
I've wondered about this, and it has been brought up a few times. The pop-off is "upstream" of the pressure regulator that Airstream installed; so...is it a "belt and suspenders" kind of thing? or was it possible for the onboard pumps of the day to over-pressure, from inside? the water heaters should have had their own...and thats what some people say: "there's one on the water heater, so you don't need one back there". Seems to me that it is an inexpensive backup for all 3 sources of over-pressure. (water heater, pump, city pressure regulator).
Is that correct?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
What a relief to recover after Aluminitis ! qqq Our Community 16 03-19-2008 02:06 PM
Pressure relief valve CBsquidSS Fresh Water Systems 4 03-03-2008 02:43 PM
water heater pressure relief valve wayne.yl Water Heaters, Filters & Pumps 12 04-21-2007 05:54 AM
Do I need this "second" relief valve? Fyrzowt Water Heaters, Filters & Pumps 20 11-22-2006 11:31 AM
Bowen Pressure relief valve melprice Water Heaters, Filters & Pumps 5 06-16-2002 06:47 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
