Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 05-15-2008, 07:14 PM   #1
twiggy137
Profile:  1973 23' Safari
northfield , Massachusetts
pressure relief ? again
hoping to redo plumbing this weekend ,73 23' safari replacing city water pressure reducer,check valve,and pressure relief valve,all located in rear bath.watts co lists different pressure relief valves.relief at 50,75,100psi
anyone now what pressure.thanks Don
twiggy137 is offline   Reply With Quote
Old 05-15-2008, 07:28 PM   #2
RUSSELL
Desert Fox
Profile:  1985 31' Sovereign
Tucson , Arizona
Smile Hi
I do not know exacly but I would pick the lowest possible. The plastic lines do not like high pressure. I have and inside pressure relif and I hook up one on the hose to lower it more.
Regards from Russell in Cloudy Tucson Az.
RUSSELL is offline   Reply With Quote
Old 05-15-2008, 07:33 PM   #3
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I think many of the fixed pressure regulators are set around 42-45 psi. I set my adjustable Watts unit at 54 psi and the tag on my internal Watts unit says 45 psi best I can remember.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-15-2008, 07:36 PM   #4
twiggy137
hi russel
if i pick the lowest 50,won't it be to close to the city water reducer setting of 40-50 psi thanks Don
pressure relief valve twiggy137 Plumbing - Systems & Fixtures 10 05-13-2008 08:20 AM
What a relief to recover after Aluminitis ! qqq Our Community 16 03-19-2008 02:06 PM
Pressure relief valve CBsquidSS Fresh Water Systems 4 03-03-2008 02:43 PM
water heater pressure relief valve wayne.yl Water Heaters, Filters & Pumps 12 04-21-2007 05:54 AM
Bowen Pressure relief valve melprice Water Heaters, Filters & Pumps 5 06-16-2002 06:47 AM
