Old 03-24-2015, 05:24 AM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Pressure regulator
Newby question. My new 2015 FC 28 has built in pressure regulator. Is there a need to also use a pressure regulator at water source?
DeltaRon is offline   Reply With Quote
Old 03-24-2015, 05:31 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Not really necessary to protect the trailer for the reason you state. But some people will use one on the campground spigot (especially during hot weather) to protect their hose.
Bob Martel
WBCCI# 5766
Old 07-14-2015, 12:10 PM   #3
1978 31' Sovereign
Euless , Texas
I have a 1978 31' AS rear bath. The internal city water pressure regulator is not working properly. Initially I have 45 pounds at bathroom faucet then it drops so low that my tankless water heater will not stay on due to lack of sufficient flow. I attempted to adjust the pressure regulator screwing the top stem up and down, but nothing changes. I am thinking about either replacing the regulator (any sources) or just taking it out and using a 40-50 pound inline regulator at the hose bib. Any suggestions?
rbcarbo is offline   Reply With Quote
Old 07-14-2015, 04:00 PM   #4
Mission , Texas
I'd clean the hose screens first, regulators seldom go bad.
How do you know you have 45 psi at the faucet?
I replumbed my 75 Overlander with PEX recently to include all faucets, valves and the pressure regulator (which I found at Camping World, has a gauge and is adjustable, and made for a hose). I use a cheapo regulator to protect the hose.
nrgtrakr is offline   Reply With Quote
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Any PLUMBERS out there?? Pressure regulator, water pump questions SmokelessJoe Water Heaters, Filters & Pumps 65 01-11-2007 03:01 PM
black tank flush - pressure regulator? bradk Waste Systems, Tanks & Totes 12 04-30-2006 06:08 AM
Pressure Regulator Cracker Fresh Water Systems 1 08-07-2004 12:05 AM
Pressure Regulator pjtaia LP Gas, Piping, Tanks & Regulators 4 09-24-2002 07:26 PM
