Old 02-13-2010, 02:37 PM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Question Plumbing tip needed!
I am having fits trying to attach 1 1/2 in spa tubing to a barbed fitting. The spa tubing is just a tad too small to get onto the the barbs. I tried heating the tubing in hot water thinking that would help it stretch some but this had the effect of making the tubing to pliable to push on. I know there has to be a trick to this, someone help me out here. Thanks!
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-13-2010, 02:41 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Since the male fitting is barbed, soap both surfaces with diluted dishwashing soap after warming the hose.
NOT dishWASHER detergent.
Tom
Old 02-13-2010, 04:05 PM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Tom
Didn't work
Rodney
and the
My Blog
Old 02-13-2010, 04:21 PM   #4
TomW's Avatar
1967 26' Overlander
Try again
Originally Posted by Gen Disarray View Post
Didn't work
It will work. Perhaps you overheated the hose.
On the other hand, you may have simply bought the wrong matching hose or fitting.
I saw Lewster checking this thread. While he doesn't post anymore, I will bet he would answer a PM should you send him one. He strikes me as willing to impart useful advice.
Tom
Old 02-13-2010, 04:27 PM   #5
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
I am so sick of this plumbing crap. Why the *&%$ everything of a given size wont fit everything else is a mystery to me. The sewer outflow from the black tank is 3 inch of schedule something or other and wont fit the other schedule something other (still 3 inch) that the new sewer fitting is. Inch and a half spa hose doesn't go on an inch and a half fitting. Talk about BS. You shouldn't need a decoder ring to make this stuff work. Makes me sick of the camper, and I do mean fed up.
Rodney
and the
My Blog
Old 02-13-2010, 05:23 PM   #6
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
If it is true spa hose pvc,it will glue into a 11/2 pvc sch 40 fitting,if your barb is by male,buy a 1 1/2 male adapter,screw it into the female then glue the joint. Dave
easyride is offline   Reply With Quote
Old 02-13-2010, 05:30 PM   #7
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Question I wonder if this would work.....
I wonder what would happen if I took my Dremel tool and cut a small grove in the male fitting so it could compress a bit and allow the spa hose to go on.
Rodney
and the
My Blog
Old 02-13-2010, 05:45 PM   #8
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Might work cut at least 3 slices soap up really really good so it will keep going past the slits
Garry
Old 02-13-2010, 05:46 PM   #9
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Gen,
Take an razor or Exacto knife and bevel the tubing on the inside about a 1/4 inch into the tubeing Lube with your favorite lube (soap) and push. Also - insert the barb fitting into a pipe union and screw on a pipe extension of about 6 inches - gives you much more surface to grip than the small fitting alone.
been there - done that - screamed my head off - nobody heard me, I was under a house................
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 02-14-2010, 01:09 PM   #10
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
I went back out this morning fortified with a nights sleep and foolish optimism. I found a couple other fittings I had and sure enough the barbed section of the fitting I was working on was noticeably larger in diameter than the others. Is the plumbing industry the last one on the planet to catch on to industry wide standardization?
With the use of boiling water to heat the hose, a pair of tin snips to stretch the heated hose from the inside, some dish soap to make everything hard to hold onto, and a pair of channel locks to force the spa tubing over the barbs, the tubing finally went into place.
I don't think anything would have gotten the original fitting to work. To all members of the plumbing industry: if I have posted anything in this thread that hurt your feelings, I would like to extend to you an completely sincere and heartfelt middle finger.
Rodney
and the
My Blog
Old 02-14-2010, 02:26 PM   #11
TomW's Avatar
1967 26' Overlander
What a Kodak moment
... Is the plumbing industry the last one on the planet to catch on to industry wide standardization?
With the use of boiling water ... [and] a pair of tin snips ... [and] some dish soap to make everything hard to hold onto, and a pair of channel locks ... [and] a heartfelt middle finger... [the task is done]
I wish I had been there with my camera.
Thanks for the followup - I am glad your plumbing is now connected.
Hopefully, you will not need to dissassemble it anytime soon...
Tom
Old 02-22-2010, 05:36 AM   #12
Arrowstream's Avatar
Columbia , South Carolina
Chill the barbed fitting in the freezer, warm and lube the hose.
Arrowstream is offline   Reply With Quote
Old 02-22-2010, 06:13 AM   #13
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Rodney,
Chill the beer mug in the freezer, warm and lube your feet, pour the beer, enjoy the moment -- Way to stay with it.
I went through similar last year in Canada with propane gas hose for old Primus campstove. Took three days of going back and trying again. Heated one thing, chilled another, almost cut my hands off. Finally got it.
And ditto on your New Yorker salute for those industry standards promulgators.
Best,
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
'78 Argosy 24 Plumbing help needed rgolemba Fresh Water Systems 10 11-03-2009 03:43 PM
Plumbing tip and Discovery campman All Argosy Trailers 2 03-11-2009 03:32 PM
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
Another Tip.... Safari Tim Our Community 2 01-15-2004 05:32 PM
