Old 06-14-2012, 03:32 PM   #1
2005 16' Safari
Evergreen , Colorado
Plumbing Leak
When filling our fresh water tank for the season, I could hear a loud spraying noise below the seam in the floor along the bathroom wall. 2005 Bambi 16'.
Water then came up thru the seam and got the floor wet. How do I access the below floor pipes? Thanks
Paul M. is offline   Reply With Quote
Old 06-14-2012, 03:49 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
Can you be prolific and specific about what you're doing, and how you're doing it?
Old 06-15-2012, 07:21 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
AFAIK the plumbing is run above the floor in all Airstreams. You will have to look for removable access panels, in cabinets and storage compartments to find the source of the leak. In some cases you may have to remove something to get to it.
Aaron
WBCCI #XXXX AIR #2495
Old 06-16-2012, 10:56 AM   #4
2005 16' Safari
Aaron
Old 06-16-2012, 10:58 AM   #5
2005 16' Safari
Thanks, I have identified the big leak in the area under the toilet wall along the back. I can't pin it down. I've raised the back panel under the bed and i've removed the toilet. Of course the leak is right between the two. I"d like to remove the back wall of the bathroom. Is that possible? Any other suggestions?
Old 06-16-2012, 12:22 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Paul,
I am not at all familiar with your year or size of trailer. Hopefully someone else is. I know how to get a 70's vintage apart.
Aaron
