Old 06-15-2008, 07:27 PM   #1
1965 22' Safari
memphis , Tennessee
Plumbing Configuration Questions
Hi, I have a 1965 safari and have started the renovation process. i have gutted the inside and started repairing the rear floor. i am trying to figure out if my plumbing configuration is original or not. my black tank was beneath the subfloor and if you'll notice in the pic attached that everything (even grey water) drained into it.
A friend of mine is working on a 69 caraval and said his tank was on top of the subfloor.
i am also looking for suggestions as to how to put this septic system back together. do i need to reconfigure from what i have or should i replicate what is already there?
thx,
bob
rburditt is offline   Reply With Quote
Old 06-15-2008, 10:42 PM   #2
bedfords's Avatar
1975 29' Ambassador
Littleton , Colorado
I can't answer you on what the original looked like. But in regards to replacing/changing what you have now--Are you changing the configuration of the bath room? Did it work before you started your renovations? I can't speak from experience on the gray water vs black water tank but I have hared that you want to be able to collect gray water in a separate tank (one of those blue tanks that have a handle and wheels) so you don't have to pull the trailer to the dump station as often. I can't seem to find a pic of how my Overlander's gray water tied in down stream of the black water tank. The problem was that there was no valve on the gray water side of the system so if you poured a drink down the kitchen sink it was coming out the main outlet. I assumed that a blue tank was needed anytime the trailer was in use with out full hookups. Hope I helped?
Master of the Tin-Can
and thats not saying much
bedfords is offline   Reply With Quote
Old 06-16-2008, 12:02 AM   #3
GreatPumpkin's Avatar
Colville , Washington
Images: 70
thx,
bob
I can't tell from your pics, but if the grey water drains directly into the black tank, then it has been modified. Every thing I can see appears to be original or closely replicating the original set-up. Later years the black tank is above the floor, but yours is original to be under the floor.
Look closer at your grey drain - if it hits the main outlet after the gate valve on the black tank then it is as it was originally. In '65 they typically dug a hole and/or just let the grey run out on the ground. Most campgrounds frown on this today and require a blue boy.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 06-16-2008, 02:38 PM   #4
crowldawg's Avatar
1966 20' Globetrotter
Orient , New York
My 66 Globtrotter has no grey water tank. It T's into the black water outlet .I need to use a blueboy for the grey water.The black water tank is above the subfloor and has its own dump valve.
The original owners manual advises digging a "gopher hole " to let your grey water run out .Not to many places allow that any more.lol
crowldawg is offline   Reply With Quote
Plumbing success and questions Lothlorian Fresh Water Systems 0 05-31-2008 03:39 PM
Plumbing questions '79 30' argosy Bob Fonseca All Argosy Trailers 0 04-20-2008 07:49 PM
plumbing questions hickam Fresh Water Systems 9 03-25-2005 01:48 PM
Gas Plumbing Questions aztlanco Plumbing - Systems & Fixtures 15 09-20-2004 12:42 PM
Help! Bubble plumbing questions 58BUBBLE Fresh Water Systems 3 08-27-2004 01:09 PM
