Old 03-04-2014, 07:24 AM   #1
1972 21' Globetrotter
Wylie , Texas
Plumber's putty vs. silicone for shower pan
I had been planning on using plumbers putty, but the assistant at HD suggested silicone due to the movement from the flexible plastic material. He cited his own personal experience with his trailer and that the putty may crack over time. Any thoughts on what to best to use between the metal shower drain and abs shower pan to get the best seal?
rippie is offline   Reply With Quote
Old 03-04-2014, 07:34 AM   #2
1981 31' Excella II
New Market , Alabama
Typically there is a rubber gasket. Just about any sealant you use will breakdown over time. I used silicone on a sink drain and it leaks after a few years. I don't recommend the polyurethanes either.
Perry
Old 03-04-2014, 07:36 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Use silicone at your peril. From my experience, it will quickly lose adhesion and you can't put anything over it. Quality putty or a polyurethane sealant will serve you well for years and can be repaired or added to if required.
Old 03-04-2014, 07:40 AM   #4
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
You can check out the 3M line of marine sealants at West Marine, or another boat supply store. The "5200" is designed for below waterline use; there are other lesser sealants with different levels of adhesion. I have only used these on my boat, not my Airstream.
Cannonball is offline   Reply With Quote
Old 03-04-2014, 07:41 AM   #5
Wylie , Texas
The drain I have came with a gasket for below the pan (with directions for putty for top seal). Should I just look to also get another gasket for between drain and pan as a primary seal?
Old 03-04-2014, 07:49 AM   #6
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I have had good experience with "Marine Goop." It is available in tubes at HD, Lowes, etc. It will adhere to wet surfaces and does not seem to break down with time.
John W. Irwin
WBCCI #9632
Old 03-04-2014, 07:58 AM   #7
1977 Argosy 24
Milltown , Wisconsin
Don't put another rubber gasket on the top of the shower pan. It will raise the drain too high for all the water to drain out. I have used the furnished rubber gasket on the bottom of the shower pan, and plumbers putty on the top on 4 trailers and never had one leak.
ventport is offline   Reply With Quote
Old 03-04-2014, 08:12 AM   #8
Wayward's Avatar
Cary , North Carolina
Plumbers putty takes a loooong time to dry out. Just last weekend I removed an 11 year old garbage disposal and the plumbers putty was still pliable.
If that guy had it dry out prematurely, there may not have been a good tight fit, letting air in. Some porcelain sinks and tubs have variations in the flange surface.
It is low tech but works. It is spec'd still for surface to surface fits, where there is some expansion/contraction movement between the parts.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 03-04-2014, 05:13 PM   #9
Wylie , Texas
Thanks for the replies. Went back to original plan: plumbers putty. Until I'm about to apply and read in all caps "DO NOT USE ON PLASTIC" and directed to use silicone. I'm still wanting to use putty, but is there another variant. Or is putty just putty. Btw, this is from Home Depot.
Old 03-04-2014, 05:32 PM   #10
1977 Argosy 24
I have used it on plastic sinks, and showers with no ill effects. I guess I just didn't read the warning. The corporate lawyers probably just put on the putty container (just in case) it screwed something up.
Old 03-04-2014, 05:48 PM   #11
Wylie , Texas
Thanks vent port. I think the assumption is that it won't be well secured. But with a metal drain lip over and metal nut under, should be fine. As I dry fit the drain-pan- gasket-nut, the pan sits up high at this point because of the gasket and nut being above subfloor. I had cut a roughly 1 1/2" hole for the drain. Do I just need to extend the hole in the subfloor out to make room for the these, which I hadnt accounted for when I made the orig. hole? This area was completely rotted so I had no idea for my template how big the hole was supposed to be.
Old 03-04-2014, 06:10 PM   #12
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Plumbers putty doesn't get hard enough to crack for a long time and is much easier to remove than silicone (the drain could leak, but be much, much harder to remove if siliconed, then you have to clean the stuff off…0. If the container had been opened some time ago, it will get hard faster and lose it's flexibility, so use a new container. Never had any problem on plastic either.
Gene
Gene
Old 03-04-2014, 07:29 PM   #13
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Some manufacturers make a plumbers putty that can be used on marble, plastics and other materials that regular plumbers putty can't be used on. Even these state that they are not for use on ABS, though. It's my understanding the petroleum-based putty reacts with the ABS and will cause the ABS to crack over time. All putty manufacturers recommend silicone for use with ABS.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 03-04-2014, 07:38 PM   #14
Wylie , Texas
Lewster recommends polyurethane. So, what about trem pro/vulkem?
How do I remove the belly pan? aluminitus Belly Pans & Banana Wraps 19 10-21-2014 10:50 AM
Silicone caulk on aluminum edglenn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 43 12-21-2012 07:48 PM
New drip pan Farmer Dan Furnaces, Heaters, Fireplaces & Air Conditioning 2 09-09-2012 08:44 PM
Silicone tent seam sealant over rivet heads jayg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-10-2011 10:25 AM
Dent in water tank galvanized pan safariuser Belly Pans & Banana Wraps 1 02-26-2011 05:37 PM
