Old 03-04-2014, 08:06 PM   #15
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
3M marine products can not be beat. The 5200 is really strong and long lasting stuff....trying to get it off is a night mare.
They make a more gentle bedding compound (101? as I recall) that would be better suited for your app.
Del Gurney is offline   Reply With Quote
Old 03-04-2014, 09:32 PM   #16
richw46's Avatar
Lexington , Kentucky
I have used Permatex Ultra Black RTV silicone gasket maker for a number of different projects. It's pretty tough, but it is black. I've sealed around my windshield, sealed around valve cover bolts, even used it to fill in holes make by rocks in the headlight lenses of my old '91 Camry. Regular household silicone wouldn't last long but this stuff seems to be really strong. I have filled in 2 pretty good sized holes in the headlight lenses and they've stood up to 3 winters now. One hole was big enough to put quarters in. I had to layer in the silicone over a couple of days.
The only down side I've seen is that it is black and will get on everything if you aren't careful, but once cured, it stays put.
Just throwing that out there
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
How do I remove the belly pan? aluminitus Belly Pans & Banana Wraps 19 10-21-2014 10:50 AM
Silicone caulk on aluminum edglenn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 43 12-21-2012 07:48 PM
New drip pan Farmer Dan Furnaces, Heaters, Fireplaces & Air Conditioning 2 09-09-2012 08:44 PM
Silicone tent seam sealant over rivet heads jayg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-10-2011 10:25 AM
Dent in water tank galvanized pan safariuser Belly Pans & Banana Wraps 1 02-26-2011 05:37 PM
