Old 07-10-2015, 05:17 PM   #1
groovzilla's Avatar
1966 20' Globetrotter
Seattle , Washington
please help - 1959 soft copper fittings
all,
i am replacing a small 8' section of soft copper water line and having an extremely hard time finding the proper fitting thread for the 3/8 copper fittings that were originally used on the water line connectors?
i've checked with all the local plumbing supply and fitting supply companies and they have nothing to match the small fine threads on the 3/8 copper fittings that connect to the existing fittings
has anyone been able to located these fine thread male and female fittings?? photo attached of the original male fitting i'm looking for
Name:	airstream water fitting.jpg
groovzilla is offline   Reply With Quote
Old 07-10-2015, 05:56 PM   #2
Mission , Texas
My 75 Overlander had flare fittings for most of the copper water lines except a couple of compression fittings.
Can't tell from the photo as I'm on my phone, but if there is a brass ring on the copper it is a compression fitting.
Try a True Value ... the one's I've used have things the big box stores don't.
nrgtrakr is offline   Reply With Quote
Old 07-10-2015, 06:10 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
You can buy those compression rings separately, so you could just re-use the old fittings with new pipe.
That piece that you show in your photo is one part of a complete fitting (tee, coupling, etc.) If you need just that piece, you will have to buy the whole fitting to get it.
Alan
Old 07-10-2015, 07:23 PM   #4
Central , Mississippi
Thats goofy, it looks like a 3/8 male NPT stuck behind a compression fitting. Are you sure it's not a previous owners cobbled up repair?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-10-2015, 08:44 PM   #5
groovzilla's Avatar
very sure - the entire trailer has the original soft copper and these original compression fittings - the copper has never been worked on so everything is original.
none of the 3/8 compression fittings in specialty stores work - the threads are too big and the diameter of the 3/8 compression fittings are too wide - none of these plumbing stores OR fitting specialty shops have any idea where to find them - i'll have to re-use the fittings from the copper i removed - it was only 1 section from water tank to the sink T - i just couldn't understand why i can;t find them?
heres a photo for comparison - 3/8 soft copper with the original fitting on right side in both photos - newer compression fitting on left side:
ID:	242645   Click image for larger version
Old 07-10-2015, 08:55 PM   #6
Kevin245's Avatar
Have you looked at www.mcmaster.com? If they don't have it...
Eleanor Roosevelt
Old 07-10-2015, 09:05 PM   #7
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Save yourself a headache, just cut it off and use a coupling or a modern fitting. The 3/8 tube is still the same.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 07-10-2015, 09:27 PM   #8
Mission , Texas
Reverse compression like the hose from your tank to the regulator.
I like PEX.
Old 07-11-2015, 09:27 AM   #9
groovzilla's Avatar
when i disconnected the soft copper pipe, i removed one end from the sink "T" and the other end from the water tank - the copper got bent and is now in 2 pieces.
i cannot remove the brass fitting in the water tank as it is practically welded in.
*since i can't find the original style fittings i'll re-use the old fittings and splice in a new fitting for the new section of pipe between the sink T and water tank fitting.
Old 07-11-2015, 10:57 AM   #10
1977 31' Sovereign
Lynnwood , Washington
I'm finding that old school brass fittings are becoming more and more obsolete by the day. If you can't find what you need, you'll hafta upgrade with what's available.
I've found Ace Hdwe to be the place for brass fittings. They've got pretty good selection. Specifically, I've found that franchise stores have much better selection than corporate stores. In Woodinvolle, WA, that would be McLendon's Hdwe.
Other than that, you should try an industrial hose and fitting supply store. In Everett, WA, that would be North Sound Hose and Fittings and Greenshields Industrial Supply.
Tom
TomKirk is offline   Reply With Quote
Old 07-11-2015, 11:51 AM   #11
1961 24' Tradewind
1967 26' Overlander
Savannah , Georgia
While I replaced most of the copper in my 61 with PEX, I kept some where it attached to kitchen faucet, etc. as was too difficult to replace. I just used Sharkbite fittings for the transition without a problem.
Michael Higgins
beatrix1 is offline   Reply With Quote
Old 07-11-2015, 08:57 PM   #12
1996 25' Excella
Tillsonburg , Ontario
You should be able to splice onto the original piece of copper left on the tank. Take the piece you broke off to a plumbing sore or hardware store and get a new "coupling" and a new piece of copper tubing and the fitting to replace the compression fitting you show in the photo. Your tubing left on the tanks needs to be cut carefully to ensure it is round and not deformed. Worst case, you or a plumber might have to solder a compatible fitting onto the tube left on the tank.
HIHOAgRv is right: it looks cobbled...if you can take the fixture you are connecting to with you, a good hardware dealer should be able to help patch things up. with new tubing, and all the fittings
JCW
JCWDCW is offline   Reply With Quote
Copper compression fittings vs. flare fittings phippsto LP Gas, Piping, Tanks & Regulators 37 12-07-2015 03:08 PM
Need help on soft floor cooter Repairing/Replacing Floor &/or Frame 1 07-29-2011 01:53 PM
soldered copper vs. compression fittings Globie64 Fresh Water Systems 6 11-18-2009 11:25 AM
Replace copper connection with standard fittings mello mike Fresh Water Systems 1 06-28-2009 11:56 PM
LP Wierdness / Where to buy copper LP pipe and fittings? nickglase LP Gas, Piping, Tanks & Regulators 19 03-11-2006 03:43 PM
