Old 06-05-2014, 12:19 PM   #1
thyatt
1968 26' Overlander
Holdrege , Nebraska
Rivet Please explain how water pressure works
All,
I am rebuilding a airstream from frame up. Thankfully, I am almost to plumbing!
How does water pressure work with an airstream? From what I can tell there is no pressure tank normally. When water is needed to a shower or somewhere else, is this task solely managed by the water pump? If so how does the water pump know when to turn on and off. I appreciate any answers. I will need to buy components soon for our 24 foot Overlander. My only draw for water will be to a single sink, shower and toilet.
tysonhyatt is offline   Reply With Quote
Old 06-05-2014, 12:24 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
The water pump has a built-in pressure switch on the discharge line. When the pressure drops, the pump starts and builds pressure. The pressure buildss until it opens the switch - then the pump stops again.
When you turn on a faucet, that drops the pressure - and vice versa.
The pump draws out of the fresh water tank, which is not pressurized.
Old 06-05-2014, 12:29 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
OR... If you are in a campground with hookups for water, you connect your white hose to the camper's clean water inlet and water pressure maintained by the campground is used. It works just like the city water you have in your home.
The pump only needs to be turned on when you want to draw water from your onboard supply tank.
Paula
Old 06-05-2014, 01:53 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by tysonhyatt View Post
All,
These are what are called "demand pumps."
Although there is no pressure tank as such, there is some elasticity in the piping and the water heater that will buffer the output from the pump running around half a second or so. The pump has a pressure switch and turns on when you open a faucet, off when you close it. Sometimes it will cycle a little if you have the faucet halfway open.
Much simpler than the old systems
Old 06-05-2014, 02:03 PM   #5
thyatt
1968 26' Overlander
Holdrege , Nebraska
All,
Thanks for the replies. That helps a lot and solves many questions.
Old 06-05-2014, 02:28 PM   #6
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
For city water I would recommend a Check valve, Pressure Regulator, and Pressure overflow valve of some sorts.
Cyquest is offline   Reply With Quote
Old 06-06-2014, 07:33 AM   #7
thyatt
1968 26' Overlander
Holdrege , Nebraska
What size and brand of water pump would you recommend for a 24 ft. overlander? Total I am planning to run about 30 ft. of Pex to a single sink, a shower and a toilet.
Old 06-06-2014, 10:24 AM   #8
Gainesville , Florida
Some of the older AS gad a system with a hand pump to pressurize the tank. Do not know if yours is old enough fir this system. Jim
Old 06-06-2014, 12:39 PM   #9
thyatt
1968 26' Overlander
Holdrege , Nebraska
Actually, I am building ours custom from the frame up. So I am looking to use more modern standards.
Old 06-16-2014, 02:21 PM   #10
1961 22' Spaceliner
Boston , Massachusetts
Manual water pump and electricity draw for electric pump
I have some similar questions and thought I would add to this thread rather than starting a new one.
I'm working on building out a 1960's 22-footer with an intention of being able to make it a week or so at a time "off grid." I'm trying to reduce electricity and water demand to the extent possible, etc. to make this easier to accomplish.
I have two questions regarding water pumps:
1) Does anyone have a manual water pump in their airstream? If so, what kind? Does it work well? Can you describe how that works?
2) How much electricity does a typical electric water pump draw. If I'm trying to get by on very minimal electricity usage, is this something to try to eliminate? On a daily basis, is it closer to LED lighting, or using a microwave, etc.?
Thanks for any advice!
jondettling is offline   Reply With Quote
Old 06-16-2014, 02:30 PM   #11
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Marine foot pumps
Many boats are built using simple foot pumps to provide water pressure.
WHALE PUMPS Gusher MKIII Cabinet-Mount Galley Foot Pump | West Marine
BambiTex is offline   Reply With Quote
Old 06-16-2014, 02:39 PM   #12
webspinner's Avatar
Menlo Park , California
I'd look at a lot of other ways to save electricity before I'd resort to a manual water pump. Compared to things that provide heat, like microwaves and incandescent bulbs, water pumps are pretty insignificant.
Here's a chart (scroll down a bit on the page) that compares the draw and likely daily load for a variety of things in an RV.
A water pump doesn't draw all that much and its use is intermittent and generally brief, so it's not the first place to look for power savings.
Barbie
Our travel and renovation blog: http://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Old 06-21-2014, 06:11 PM   #13
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Water Pump Connections
Every water pump I've seen has flexible hose (like garden hose) connecting it to the supply lines. Is there enough vibration when the pump kicks on or is what I'm seeing jury rigged plumbing? Can I go right into the pump with pex?
Indiana, PA
Roadrunner is offline   Reply With Quote
Old 06-21-2014, 06:34 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I believe the flex hose has 2 purposes. Vibration and Noise reduction.
The pump will rattle the PEX and you will hear it throughout the coach.
IMHO
TG Twinkie is online now   Reply With Quote
Explain the water/holding tank system to me? truebebeblue Waste Systems, Tanks & Totes 2 03-25-2006 05:07 PM
Please explain the Jacobs and MSD ignition systems guy99 Mechanics Corner - Engines, Transmission & More... 9 02-09-2006 07:00 PM
please explain Weight Distribution pinkflamingoes Hitches, Couplers & Balls 13 05-30-2004 01:55 PM
Explain this Dump Valve behavior..... Chuck Waste Systems, Tanks & Totes 2 08-28-2003 11:18 AM
Dear Santa...I can explain! KY Girl Off Topic Forum 6 12-22-2002 10:32 PM
