Old 06-12-2015, 12:11 PM   #15
1996 25' Excella
Tillsonburg , Ontario
Check your owners manual. It should tell you if you have an inspection port. Maybe those screws are part of it. All older AS had a circular plate that exposed a big screwed plug on the bottom for cleaning and winter drainage...which most us never use
JCW
JCWDCW is offline   Reply With Quote
Fresh water tank drain valve replacement lboyd Plumbing - Systems & Fixtures 21 01-10-2015 06:04 PM
Fresh water drain valve replacement Winetripper Fresh Water Systems 19 10-22-2012 07:28 PM
Replacing Plastic water drain valve with metal wolverine Fresh Water Systems 8 05-22-2009 08:32 AM
Plastic water drain valve Waterman Plumbing - Systems & Fixtures 5 10-29-2003 10:51 AM
