Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 04-13-2009, 03:28 PM   #1
tdoescher's Avatar
Profile:  1969 31' Sovereign
madison , Wisconsin
Red face pex plumbing question
My 69 Sovereign has a couple of copper water pipes that appear to be split/cracked I am assuming from not draining properly in the winter
It seems like favorite product used to repair is the pex product.
Does anyone know the recommended size used to connect to the original plumbing?
Do they make an easy connector to connect the copper pipe to the pex tubing.
tdoescher is offline   Reply With Quote
Old 04-13-2009, 03:44 PM   #2
Profile:  1977 31' Sovereign
Manchester , New Hampshire
Images: 33
I used 1/2 inch size all the way through except on the water pump had to down size to 3/8 I believe it looks great to red and blue no making mistakes.
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 04-13-2009, 03:45 PM   #3
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Sea Tec fitting and all other quick connect/disconnect plastic fitting are made size for size with all other plumbing pipe sizes.
These fittings just slip over the copper pipe and seal with a O ring. You can disconnect them without tools. Just cut out the bad section of copper and slip in the new.
If you were redoing the complete trailer Pex might be the way to go but for small repairs you can't beat Sea Tec.
It took me longer to type this than it will take you to replace you problem.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 04-13-2009, 03:45 PM   #4
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 42
use the search function here
In the blue bar above....search..... there was a good discussion here last year Good luck....the crimp tool is expensive if you go that way.
Old 04-13-2009, 03:47 PM   #5
Images: 33
The big buck items are the fittings not the PEX pipe so make sure you don't over do it .The great thing about pex is it connect's to copper very well make sure you clean the connection though. good luck
K/N Cool intake air
Duel power exhaust
Old 04-13-2009, 03:51 PM   #6
Images: 33
Well PEX is great all around as far as temps go it expands and unless it is -30 below I beleive it won't split look through my images I did whole thing pex, waiting on pump now and RV-500 water heater then plumbing will be done.
K/N Cool intake air
Duel power exhaust
Old 06-09-2009, 10:39 PM   #7
rustyrivet's Avatar
Profile:  2005 22' Safari
Gresham , Oregon
Most of the discussion is regarding Pex used in water lines. I need to shorten the line that leads to my propane tanks and discovered that the pipe that needs to be shortened is made of PEX. I spoke to the local hardware store regarding the fitting to connect to the flex rubber hose that goes to the propane tank to the PEX. He informed me that he didn't think it was legal to use PEX for a propane line in this county and that He usually recommended "shark bite" or something similar for water lines but would not recommend it for propane. Said I should be using black pipe or copper. All I need to do is shorten the pipe about a foot so I can attach a bracket to the A Frame for a new hitch. I just don't know anything about PEX and hope someone has some experience with this. jc
rustyrivet is offline   Reply With Quote
Old 06-09-2009, 11:15 PM   #8
Profile:  1974 Argosy 26
Hamilton , Montana
Pex for gas lines?
Pex is a no-no for gas lines! Most RV's used copper pipe with flare fittings, and then an approved rubber hose to connect to the tank regulator. Make sure that line is not copper. A simple flare coupling would shorten the pipe. Otherwise replace with rolled soft copper of the right size with flare fittings.
Dave the plumber
Montique is offline   Reply With Quote
Old 06-09-2009, 11:16 PM   #9
georgezink's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Lawrenceville , Georgia
Your hardware store is right. Do not use Pex for a gas line -- it should only be used for hot or cold water. You should replace your gas line with copper or black pipe -- copper will be easier to work with.
flcracker
georgezink is offline   Reply With Quote
Old 06-09-2009, 11:23 PM   #10
2dabeach's Avatar
Profile:  2007 25' Safari FB SE
North/East , New Jersey
rustyrivet...Here is some information from page 9 of the the SharkBite PEX Installation Guide:
"Do not use with natural gas, propane, fuel oil or any other fluid, chemical or product. SharkBite PEX tubing (non oxygen barrier) is for use with potable water only and is not approved or intended for any other use"
http://www.cashacme.com/_images/pdf_...EX_Install.pdf
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
WBCCI # 8459
2dabeach is offline   Reply With Quote
Old 06-15-2009, 07:01 PM   #11
rustyrivet's Avatar
Gresham , Oregon
Thank you all. This is very confusing. I bought my Airstream Safari used (2005 model). I have never had to change any of the pipes; water or propane. I assumed, perhaps incorrectly, that the PEX pipe to the propane tank was factory installed by Airstream. Some on the forum say they have replaced their systems with pex and others say it is a definite no-no. The quote by 2daBeach, from the SharkBite manual sounds very definitive. I may need to run an entirely new copper propane line. I am going to contact Airstream and see if PEX was factory installed for propane on 2005 Safari's.jc
Old 06-15-2009, 07:12 PM   #12
Vagabond
DIMMER's Avatar
Profile:  1973 31' Sovereign
Semi, Pro Rock Crawler , Motorsports Photographer
Images: 36
Send a message via AIM to DIMMER
I would like to see pic's of PEX being used a LP line!!
DIMMER
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
DIMMER is offline   Reply With Quote
Old 06-15-2009, 08:26 PM   #13
atobols's Avatar
Profile:  1974 27' Overlander
Jeromesville , Ohio
With regards to the original post in the thread...
Perhaps by now the job is already complete, but PEX is for sure the way to go. I recently had EXACTLY the same issue as you. My "burst" was under the tub area on my '74 Overlander. So, I cut the copper in the trunk and under the mid-gaucho. I bent and yanked until all came out the back. I installed the new stuff with sharkbite connectors. Yeah, a bit pricey, but extremely simple and easy.
The main pitfall and not at all related to PEX: the copper tubing in my trailer, at least the line that blew, was thin-wall copper. It's the stuff that you buy in coils rather than straight sections. Anyway, it had expanded a few times due to freezing apparently and wouldn't fit anything that's was a connector for 1/2" line. I ended up going to my local plumbing supply store with a chunk of the offending copper, they explained the likely scenario, and then we went to their copper storage area and just checked until we found a section of 1/2" copper that snugly fit the expanded chunk. So, I had to sweat on a short section of the 1/2" copper to each of the wrong-sized thin wall copper and then I was able to get the sharkbites to bite and then everything went together like a really easy jigsaw puzzle.
Jason & Andrea
atobols is offline   Reply With Quote
Old 06-15-2009, 08:39 PM   #14
2dabeach's Avatar
rustyrivit....There is no "This is very confusing". The folks responding to this thread that indicated that they used PEX were referring to its use in the presurized water system of their Airstream. NONE of the folks responding to this thread indicated that PEX was to be used on the propane system. Its very clear, PEX IS NOT TO BE USED ON THE PROPANE SYSTEM. I'm sorry to be this direct. I don't want you walking away from this forum and end up with an unsafe trailer.
WBCCI # 8459
Pex Connector Question Jim & Susan Fresh Water Systems 9 03-03-2009 07:28 AM
Pex line and flair-it fittings question Frieberg Plumbing - Systems & Fixtures 3 10-13-2008 08:40 PM
Re-plumbing 1/2 or 3/8 PEX Gen Disarray Fresh Water Systems 5 03-04-2007 09:52 PM
Per-PEX-ing Question soldiermedic Fresh Water Systems 19 11-07-2006 09:13 AM
PEX Plumbing on DIY GlenCoombe Fresh Water Systems 6 08-06-2006 01:54 PM
