Old 09-01-2012, 06:38 PM   #1
1981 31' Excella II
New Market , Alabama
PEX crimpers are there any good ones?
Well I have had my first experience with PEX. I bought one of those pocket crimper deals that you use with vise grips. I can tell you that this is not the way to go for a main tool. I would say it is good for occasional or emergency use but it is not practical for more than two or three crimps before your forearms are toast. It also takes repeated crimp tighten, crimp tighten cycles to get a good crimp. It might be good for tight spaces but it is not very easy to use even when you have plenty of room to work.
So does anyone have any experience with a better crimper that does not cost over $100 and will do multiple sizes like 3/8", 1/2", and 3/4"? I want something that crimps the copper rings not the stainless steel pinch clamps. I don't think that pinching on the sides is as good as a continous ring.
Perry
Old 09-01-2012, 06:44 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I have one of those for tight spots and the big cable cutter type in 1/2 inch only from Home Depot for $49 I think. Since I have never had need for 3/8 or 3/4 I just stuck with the 1/2 inch. The pocket one will do bigger if I need it. These big ones work great and I have never had a leak, and your arms don't get tiered.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-01-2012, 06:50 PM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Viega
Even though it is much more than you want to spend I recommend Viega. I have this tool and use this system. "Spend the big bucks and do it right the first time" says Dennis.
Lance
Top is offline   Reply With Quote
Old 09-01-2012, 07:54 PM   #4
1974 Argosy 20
Kooskia , Idaho
I have a multi size PEX crimper from Home Depot, it is well made and works very well. As I recall it was about $90. It has a plastic case included which holds all the parts. I can't recall the name, and I am not home now to look, but I think it is the one sold at all the Home Depots.
Old 09-01-2012, 08:00 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Lowes has a tool that works with the stainless steel crimp rings for both 3/8 and 1/2 for about 40 bucks. Works fine. Not really a ratchet like they say but it does work well. Sometimes you have to look for them in the store, and not all stores have the same thing. I saw a longer one for about 100, but am happy with the short one. Stays in the trailer with a pack of rings. So far in 2 years I have not had a joint I made leak. I have done a couple over when it did not "feel" right. A good tip with pex is to buy the cutting tool also. A clean, straight cut is a big help in getting the joints assembled tightly. If the cut is an an angle or fuzzy it is hard to get and hold the tube all the way up in the fitting when crimping.
Old 09-01-2012, 08:01 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
I got my 1/2" crimper at Menards. It's a long handle type. I think I paid $45 or $50. It works first time every time. Everything tested with no leaks at all. I did use sharkbite connectors where the space was tight.
Old 09-01-2012, 08:14 PM   #7
Southwestern , Ohio
Unless you do a lot of PEX work I wouldn't especially recommend investing $100+ in a PEX crimper.
I use one of the "pocket crimper deals"
The Pex Pocket Crimper- For permanent crimp connections with PEX tubing fittings
but like yourself, I quickly discovered a Vise Grip pliers was not the best way to squeeze it. I use a small machinist's vise like the one pictured and it gives me a perfect crimp every time. Not fast, but can be used in tight spaces and doesn't require heroic strength. . . just patience.
Nuvite-F is offline   Reply With Quote
Old 09-01-2012, 08:25 PM   #8
1981 31' Excella II
Yeah I used my big shop vise and it was still a PIA to use.
Perry
Old 09-02-2012, 06:33 AM   #9
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Got the long handled crimper from HD, they work great. You can cheap some things on your build but good water tight connections are worth their weight in gold...esp once every thing is back together. Spend the extra moola a good set. I know money wise they ain't cheap but neither is the hassle of a re-tear down...
.02
goshawks00 is offline   Reply With Quote
Old 09-02-2012, 06:39 AM   #10
Riverrat6270's Avatar
1980 31' Excella II
Springfield , Illinois
Look at the crimpers made by Sioux Chief and sold at Menards. Have used the crimpers in over 100 homes and finally wore one out. Crimps 1/2 and 3/4 and never had a leak.
Riverrat6270 is offline   Reply With Quote
Old 09-02-2012, 09:00 AM   #11
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Have you thought about the tool rental places? Even the Home Depot in our area rents the Professional crimper at a very low daily rate.
fltlevel510 is offline   Reply With Quote
Old 09-02-2012, 10:38 AM   #12
1988 25' Excella
1987 32' Excella
Not sure why people freak out at paying 50-100 for a tool that does good work and will last a long time and actully makes plumbing closer to fun. You could hire a Airstream tech that already has one and he will probably charge you 50-100 to get his out of his tool box and put it back in.
Old 09-04-2012, 05:06 PM   #13
Phoenix , Arizona
That is a fact. Buy the right tool for the job.
M2HB is offline   Reply With Quote
Old 09-04-2012, 06:12 PM   #14
1981 31' Excella II
I just bought a Shark Bite tool for like $60 at Home Depot and is appears to be well made. However, it won't compress the copper rings enough to fit the go gage that came with it. I increased the preload and it still won't compress the ring according to the gage. The gage might fit on the flattened edges where the part is in the tool jaws but it is iffy. So what is the problem here. Is there something wrong with the tool or what?
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Perry
