Old 12-31-2012, 03:43 PM   #57
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Originally Posted by VeggieBullet View Post
ok we are doing some tool and skills testing and we are wondering how tight the clamps supposed to be?
Done a couple of fittings and it looks sharp but the fitting will still turn, not easily but it will turn a little.
Is this normal?
I use the cinch clamps as opposed to the copper rings and yes you can turn the fitting in the tube. An interesting thing is once you have cinched the clamp, carefully cut the clamp off. The tubbing remains compressed on the fitting and is almost impossible to pull off the fitting. I don't know if it will hold water or if it will relax with time but it does hold on to the fitting pretty tight.
Cheers, Dan
~ Margaret Thatcher ~
Old 12-31-2012, 05:08 PM   #58
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I use the copper rings and can turn the fittings after they are squeezed. Turning them doesn't seem to create leaks.
If you cut the clamp or ring off, the connection will not hold water. If it does hold water, you are only lucky and your luck will run out.
Zep
Old 01-03-2013, 06:56 PM   #59
1989 32' Excella
Silverton , Colorado
You should have a test gauge. It simply slides over the crimp ring. If the crimp ring is to big then it's a failed crimp. I don't use plastic fittings but they might be ok. The important thing with plastic or brass fittings is they better not have any scratches. A Pex fitting will leak if it's scratched. So be careful with them. Don't leave them on the floor where they can get stepped on etc. If you keep them in their own [plastic]container where things aren't banging into them you will have less chances of problems. If they get dirty you can wash them but only use dish detergent and not any kind of solvent that I know of. Only use a clean rag or wash cloth and rinse them off well. I have salvaged brass fittings with minor scratches. But I had the micro mesh polishing system to do it with so I was able to get it to better than a 2300 grit finish. One good thing about Pex is that if it holds for ten mins it's probably good forever.
Mark Lee is offline   Reply With Quote
Old 02-09-2016, 11:03 PM   #60
2004 22' International CCD
2015 30' International
Box Elder , South Dakota
I don't do any repairs myself, but I can tell you that the little PEX-branded copper crimp bands that Airstream is using now: they allow leaks. I'm catching leaks after only 3 months of ownership. Maybe the craftsmen at Airstream were sloppy, but now I have no faith in my entire original pex system. I'm working with Abe of RV Mobile Service 2U to fix the problems.
Here, I'm pointing to a knuckle on the city water inlet pipe that started leaking today.
lbdesign is offline   Reply With Quote
Old 02-10-2016, 02:18 AM   #61
Images: 59
I did not know that Airstream uses plastic fittings instead of brass.
I used only brass fittings/copper rings when replumbing and haven't had a single leak.
I would not be suprised if the plastic fittings leak. It also looks like the ring might be placed incorrectly on the leaker, too far from the end of the tube.
Old 02-10-2016, 04:49 AM   #62
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Agree
I agree. That ring is too far from the end of the tubing.
I used brass fittings and copper crimp rings on PEX tubing for a complete replacement of our trailer's original water system back in 2008, and there have been no leaks in the PEX fittings.
It's a good system, but it doesn't tolerate sloppy installation.
Old 02-10-2016, 02:25 PM   #63
Wise Elder
Jammer's Avatar
2010 30' Classic
I agree that the ring placement is wrong.
I use the "pro" rings that have a collar at the end with an inspection hole. They are not idiot proof but they are "idiot resistant" and for a few cents more I figure it's worth it.
The plastic fittings are fine as far as leakage goes IME but they are not physically as strong as brass. The 90 degree elbows, in particular, can snap if the attached lines are pulled apart or together with force.
Old 02-10-2016, 02:35 PM   #64
Kevin245's Avatar
Pex- Clamps or Rings
Don't throw pex crimp rings or clamps under the bus. This appears to be an installation issue as referenced by others. I use both types of connectors with no issues at all. Proper setting and alignment are the keys. I do use brass fittings rather than plastic as I am not confident of their durability.
Eleanor Roosevelt
Old 02-10-2016, 04:03 PM   #65
1998 30' Excella 1000
Livingston , Texas
My '98 had all brass elbows from the factory. Surprised that they are now using plastic.
Siegmann is offline   Reply With Quote
Old 02-11-2016, 02:16 AM   #66
Thanks everybody. I've had 3 plumbing leaks in 3 months of original ownership -- all from sloppy workmanship (luckily I was in the trailer and caught them all at onset when they occurred). And as you've educated me here, it's also from the factory cheaping out on the components. I've seen lots of evidence of sloppy work. Thank you all for your comments -- it helps me know what to look for in future inspections.
Old 02-11-2016, 08:19 PM   #67
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
I would spend more on better tubing, the PEX system is solid. I believe Wirsbo publishes no leaks in umpteen years of manufacturing.
sgschwend is offline   Reply With Quote
Old 02-11-2016, 09:12 PM   #68
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Copper rings, with BRASS fittings.
Brevi tempore!
Old 02-17-2016, 05:22 PM   #69
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
Real world test: Diu!
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
louaxtjr is offline   Reply With Quote
