10-16-2012, 10:44 AM
#41
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Originally Posted by Pillow
I also noticed that smirob's larger crimpers made from bolt cutters look well done. It appears, from looking online anyway, that he does good work.
I like his compact tool better than the pocket one I got at HD, but I already have it. It is work using the vise grips, too.
Vaughan
10-16-2012, 02:04 PM
#42
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
and then we are wondering why we are addicted to the airforums?
I'm serious, this site is great, where else can you get so much info and participation from other people?
Go Airforums!!!!
Still One Nation under GOD
2 chronicles 7:14
10-16-2012, 09:15 PM
#43
Northeastern
, Kentucky
Originally Posted by Zeppelinium
That second item is a ball valve, not a compression valve.
You want a ball valve. Compression valves are found on all your faucet lines in your house, but they restrict the flow compared to a ball valve.
Zep
Just curious....what is it about a compression valve that restricts flow compared to a ball valve?
10-17-2012, 12:16 AM
#44
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
have you ever tried to look through an open compression valve? you will know the answer immediately.
Zep
10-17-2012, 11:13 PM
#45
1973 23' Safari
1977 23' Safari
Palmer Lake
Darn, if I don't discover better ways to do things every time I do them.
(disregard the following if you use two-handled faucets--they generally have a 1/2" MIP (male) connection, so you just use a simple 1/2" swivel female PEX fitting, which is the white part of the connection in the top photo below)
It doesn't look to me like compression stop valves are commonly available for PEX (compression meaning the way the valve closes, not the way it is attached to the pipes). This is a good thing. Never-the-less, using a stop valve instead of a 1/2" swivel female will reduce your connections, per photos below. If you use a swivel and you are using single lever faucets, the tubing down from the faucet will terminate in a 1/4 or 3/8 female compression fitting--this will require a male/male reduction fitting for the hookup.
The stop valve will connect directly to the PEX on one side and the faucet tubing on the other. Viola! Simple. So stop valves all around looks like a very reasonable approach, despite what I said earlier. Note that the male/male adapter below can be 1/2x3/8 or 1/2x1/4. (Note: the braided pipe in the photo is not a separate connection up to the faucet, it is part of the faucet and is permanently attached to the faucet)
Despite appearances, the stop valve on the right is a ball valve, not a compression valve. Don't confuse this with the fact that the connections on it are 1/2" PEX on one side and 1/4" compression fitting on the other.
Zep
10-18-2012, 02:38 PM
#46
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Hi Zep.
Happy that you posted this last one! Now we are happy to report that we ordered the one on the right and therefore a regular ball valve, so no worries on a flow restriction anymore.
So basically we will have something similar that what you have with the adaptors, instead of having the adaptors we will have a ball valve.
Wow you make us feel better
2 chronicles 7:14
10-18-2012, 03:05 PM
#47
1973 23' Safari
1977 23' Safari
Palmer Lake
Originally Posted by VeggieBullet
...Wow you make us feel better
Go for it.
One last correction, the faucet side of those stop valves are 3/8".
Z
10-18-2012, 04:00 PM
#48
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Z
Yes Sir. that's correct!
thanks again Z
2 chronicles 7:14
10-18-2012, 04:05 PM
#49
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Oh Z.
another question regarding the tubing it self based on looking at your installations.
how flexible is it? I really will like to avoid as many elbows as possible and according to our trailer layout I can run the line thru the basement from the front to the back(kitchen) and if I can bend them a little will be almost a straight shot to the sink.
just wondering your input on that.
2 chronicles 7:14
10-18-2012, 08:36 PM
#50
1973 23' Safari
1977 23' Safari
Palmer Lake
I don't have one of the plastic bend-holders at hand, but my recollection is that they make about a 5" radius turn. They do OK if you're making a bend flat on the floor where you can put down some clips a few inches away along the tubing, but otherwise they have trouble holding a bend that small.
I think you can plan on being able to maintain something on the order of 8" radius just by putting clips on the floor or wall. 8"l is actually pretty small.
You can heat the tubing and then put it in a tool to cool and you can get small radiuses (radii?), but I don't know what the strength/life issues might be, it's still an experiment. The tool is more for keeping the tubing from collapsing/kinking than for making the radius. Once it's cool, it maintains the bend. I used the tool not only to get smaller radii bends, but to get opposite bends close to each other.
Zep
10-19-2012, 07:04 AM
#51
Warrenton
, Virginia
These may help: Plastic Bend Supports , Wirsbo Plastic Bend Supports , PEX Plumbing , PEX Plumbing Installation - PexSupply.com
I haven't tried the heating method before. But usually the pipe will "hand bend" pretty well for small curves.
Trailer: 1948 Spartan Mansion 30'
Tow Rig 1: Hers 2010 Cadillac Escalade ESV
Tow Rig 2: His 2010 Porsche Cayenne S
Others: 1971 Chevy C-10 with 5.3 LS and T5 conversion, 1983 Jeep Cherokee Pioneer (FSJ) with 5.3 LS and SM465 conversion, 1979 Porsche 911SC
10-19-2012, 12:55 PM
#52
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
love the bend supports but where we will need to run the Pex and make the curve we will not have any kind of access more that running the lines thru
Found this in Lowes website:
...PEX is the most flexible plumbing pipe available. It can be bent around most corners without a coupling or fitting. For example, 3/8” pipe may be bent to a 4” radius and 1/2” pipe to a 5” radius....
and this in Siouxchief's website
Minimum Bend Radius
Do not bend tube too tightly. The minimum
recommend bend radius is six times the tube
size (i.e. ½″ tube = 3″ bend radius). When
making a 90° turn, use bend supports.
Full articles can be seen here:
http://www.lowes.com/PartnerSites/Ef...f/AboutPEX.pdf
http://www.siouxchief.com/Resource_/...ide%205-05.pdf
2 chronicles 7:14
11-07-2012, 11:09 PM
#53
1989 32' Excella
Silverton
I've installed many thousands of feet of Pex. I still use the brass fittings and expandable Pex rings. The only problems are that the expander tool is very expensive and you have to be careful of tubing and ring temp. The crimping ring method works well if you can get the tool into position. With that system I'd also go with the brass crimping rings.The Pex with the oxygen barrier was mostly for closed in floor heating systems. It was called Heat Pex. I wouldn't use it for potable water without doing some reading. Mainly it was designed to keep oxygen from getting into the boiler.That of course would cause internal boiler rust. Never use Pex where comes into contact with any hydro carbons chemicals or even fumes. In houses that is critical around gas hot water heaters,boilers etc.It's very tough but don't expose it to sunlight for any length of time as it breaks down.
12-16-2012, 08:24 AM
#54
RV Fixer
2013 Interstate Coach
Corpus Christi
What I have not seen in this thread is any mention of FlairIt nylon fittings and valves.....they are super great to use for roadside docs, no special tools needed. Also I use a PVC tubing cutter, works great.
May the trails you travel always be smooth, and the sun shine favorably!!
Wickedrevs
www.allritervcenter.com
12-17-2012, 08:45 AM
#55
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
I looked into it and the is tempting, the main factor was on a personal preference of staying away from plastic on fittings and valves.
Nothing wrong with them and the price factor is very attractive on them.
Found them in many vintage trailer and in good working condition, but again for us it was a matter of personal preference.
2 chronicles 7:14
12-31-2012, 01:41 PM
#56
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
ok we are doing some tool and skills testing and we are wondering how tight the clamps supposed to be?
Done a couple of fittings and it looks sharp but the fitting will still turn, not easily but it will turn a little.
Is this normal?
2 chronicles 7:14
12-31-2012, 03:43 PM
#57
1982 28' Airstream 280
Port Angeles
Is this normal?
I use the cinch clamps as opposed to the copper rings and yes you can turn the fitting in the tube. An interesting thing is once you have cinched the clamp, carefully cut the clamp off. The tubbing remains compressed on the fitting and is almost impossible to pull off the fitting. I don't know if it will hold water or if it will relax with time but it does hold on to the fitting pretty tight.
Cheers, Dan
~ Margaret Thatcher ~
12-31-2012, 05:08 PM
#58
1973 23' Safari
1977 23' Safari
Palmer Lake
I use the copper rings and can turn the fittings after they are squeezed. Turning them doesn't seem to create leaks.
If you cut the clamp or ring off, the connection will not hold water. If it does hold water, you are only lucky and your luck will run out.
Zep
01-03-2013, 06:56 PM
#59
1989 32' Excella
Silverton
You should have a test gauge. It simply slides over the crimp ring. If the crimp ring is to big then it's a failed crimp. I don't use plastic fittings but they might be ok. The important thing with plastic or brass fittings is they better not have any scratches. A Pex fitting will leak if it's scratched. So be careful with them. Don't leave them on the floor where they can get stepped on etc. If you keep them in their own [plastic]container where things aren't banging into them you will have less chances of problems. If they get dirty you can wash them but only use dish detergent and not any kind of solvent that I know of. Only use a clean rag or wash cloth and rinse them off well. I have salvaged brass fittings with minor scratches. But I had the micro mesh polishing system to do it with so I was able to get it to better than a 2300 grit finish. One good thing about Pex is that if it holds for ten mins it's probably good forever.
02-09-2016, 11:03 PM
#60
2004 22' International CCD
2015 30' International
Box Elder
, South Dakota
I don't do any repairs myself, but I can tell you that the little PEX-branded copper crimp bands that Airstream is using now: they allow leaks. I'm catching leaks after only 3 months of ownership. Maybe the craftsmen at Airstream were sloppy, but now I have no faith in my entire original pex system. I'm working with Abe of RV Mobile Service 2U to fix the problems.
Here, I'm pointing to a knuckle on the city water inlet pipe that started leaking today.
