Old 06-11-2012, 08:12 AM   #1
fireflyinva's Avatar
1961 22' Safari
Vienna , Virginia
Patching a Blue Boy
After years of neglect (we've been tankless for over 5 years), Frank Yensen fixed our plumbing and installed a grey tank. So, on our recent trip West through PA & Ohio (Alumapalooza!), we hauled out our old blue boy. However, when we realized at Airstream it was time to drain our grey tank, we notice a huge gaping crack in the blue boy. Fortunately, we were able to borrowing from the event organizers.
After seeing how expensive replacements run, i decided to try to patch it. The crack is short, but gapes about 1/4" wide. I've been thinking of doing an epoxy repair, with fiber cloth stuffed in the gap and reinforcing the surrounding surface on both sides. Is this a good approach? Are there any epoxy types to reccomend (or not)? Has anyone done this kind of repair?
Mary
Our Airstream adventure continues!
Read the details at Tales of the Toaster
fireflyinva is offline   Reply With Quote
Old 06-11-2012, 08:55 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
It all depends on what the blue boy is made of. I would suspect that it is polyethylene of some type, which is very chemical resistant. There are no glues that will adhere to polyethylene. You might be able to tell what it is if it has a "recycling" emblem on it somewhere. The number will describe the type/family of plastic. IF it is ABS, you might be able to do a "solvent weld" like is used in plumbing.
I recently tried fiberglass repairs of my plastic wheel wells (I believe I was told they are ABS). Even though I roughed them up with sandpaper to help with adhesion and cleaned them up nice, I am watching the fiberglass slowly peel away from the abs as the temperatures are now up in the 90s, and the abs and fiberglass patch certainly have a different coefficient of thermal expansion.
The one thing that might work is to do a plastic weld. Plastic welding is technique sensitive, and you have to have "filler rod" that is the exact same type of plastic as you are welding. You will also need the welder, which is like a very small high temperature heat gun. You can buy them at Harbor Freight for $50 or so, but pretty soon you have the value of a new tank.
good luck!
Old 06-11-2012, 09:10 AM   #3
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
***t-can the broken boy
considering what normally goes into a blue boy, fixing it would be a disaster waiting to happen...time is money, too, so my 2 cents would be to replace the blue boy and never look back.
easier, too.
wmarsha is offline   Reply With Quote
Old 06-11-2012, 09:32 AM   #4
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Cut some of the top off it and make a planter pot out of it. Easy to wheel inside on those nights of frost or move it as the season changes.
Dave
Old 06-11-2012, 10:00 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
easier, too.
My thought also....
I might give it one try with Marine-Tex but thats about all....
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-11-2012, 10:14 AM   #6
2005 19' Safari
GLENDALE , AZ
If the crack/gap was the result of physical damage, you may be able to patch it successfully. Depending on how your do this, you may wish to drill a hole at the ends of the crack to prevent it from continuing to spread.
However, if the crack is caused by UV light exposure and/or age, other leaks are almost certain to appear; in which case, it's time for a new one.
Old 06-11-2012, 10:19 AM   #7
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I find that the blueboy with cracks don't fill up as fast when boondocking
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 06-25-2012, 06:45 PM   #8
1971 21' Globetrotter
Cave Creek , Arizona
Patching a blueboy
Howdy!
Recently heard of a product called West Systems G flex epoxy.
Supposed to stick to Polyethylene boats and such. Haven't tried it nor heard of any results, good or bad.
Maybe you could be the Official West Systems G flex Epoxy A/S Forum Early Adopter and let us know how it works!
Worst case scenario, it doesn't work and you're out the price of the stuff.
I know, easy for me to say!
snakecharmer is offline   Reply With Quote
Old 06-25-2012, 07:04 PM   #9
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Polyethylene can be easily welded if you have the right equipment but would fail quickly if the PE was degraded by age, ozone or UV. Depending on you location you might be able to find a plastic fabricator who has the proper equipment and could evaluate the state of the plastic for slightly more money that you can locate a good tank on craigslist. I would take option 2
