Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 07-29-2003, 02:19 PM   #1
Profile:
P Trap Cup
In our trailer the shower P trap is protected by a bowl, sorta insulating the p trap- is this bowl necessary?
Chitown AirStreamers is offline   Reply With Quote
Old 07-29-2003, 02:23 PM   #2
drboyd's Avatar
Profile:
I'm guessing it is, and here's why...
If you take it off, what do you see? I imagine you'd see the edges of the fiberglass insulation between the floor and the belly skin. You really don't want to hit a puddle and splash a big load of water in there - it'll take forever to dry out, and rot your floor and rust the frame in the process...
Old 07-29-2003, 02:34 PM   #3
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Airstream Registry
I believe it also insulates the p-trap somewhat during those near-freezing nights when the trailer is still in use and not winterized by holding the interior heated air inside.
Shari
mouse mdlay General Repair Forum 13 02-28-2004 01:08 PM
You Might be a Red Neck? aviontt Off Topic Forum 6 12-15-2003 10:34 AM
Why are you home this weekend? yukionna Our Community 35 10-07-2003 05:33 PM
Wheel bearing part #s Ultradog Axles 6 05-17-2003 01:29 AM
A/C Install for 1955 Overlander Tinovations Furnaces, Heaters, Fireplaces & Air Conditioning 10 02-23-2003 11:18 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
