Old 04-11-2011, 04:42 PM   #1
2010 27' FB International
La Crescent , Minnesota
Outside shower
On our return trip from the South East, we stoped at Jackson Center to have some warranty work done. All were minor but it was a good exuse to see the factory. Amoung the items was the leak in the outside shower.
We did not check it before leaving. The problem persists.
It leaks from the housing when the valves are turned on. How is access gained to the back side? The knob come off easy enough. With the outer screws removed the housing does not want to come out.
Any advice would be appreciated.
Jay
mjayjensen is offline   Reply With Quote
Old 04-11-2011, 05:36 PM   #2
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Jay
On my 08 27FB, You will need to be somewhat of a flexible person to get to it. Open the closet, and you will see the rear of the closet has a "shelf" which is actually access to the plumbing backside there...(i.e. city water inlet, etc).
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 04-11-2011, 06:34 PM   #3
Kevin,
I looked behind the closet. The outside shower seemed to be behind the inside shower. I do not want to remove the inside shower. That seems to overwhelming.
jay
Old 04-11-2011, 08:23 PM   #4
Images: 12
Hummm... Maybe they moved them in yours? The only way to get behind the shower on the aluminum side is to remove the bedroom wall. That's way easy. There are half a dozen or so screws on the edge of the wall that screw it to the wooden frame behind it. The screws heads are usually covered with a small round plastic cap that match the wall laminate color. Pop those off and unscrew the screws. Caution that the dometic controls and light switches are attached to the wall. You should be able to scoot the wall over to one side towards the hall and then access the area between your shower and the streetside wall. Look out for the sharp fiberglass!!!!
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Do you use your shower? Scott J-24 Sinks, Showers & Toilets 117 01-16-2012 04:43 PM
Removing shower valve in 74 Argosy 24' twilder Sinks, Showers & Toilets 2 04-02-2011 08:28 PM
Wet bath to shower? osolow Sinks, Showers & Toilets 6 03-24-2011 10:25 AM
1981 Excella II shower valve noreen&sal Sinks, Showers & Toilets 2 03-06-2011 08:06 AM
Original Shower Curtain for 1967? star kitty General Interior Topics 3 02-19-2011 08:49 PM
