Old 12-05-2009, 04:14 PM   #1
1979 30' Argosy
saint augustine , Florida
Cool odd hot water pressure
here's a head scratcher for you all to help me figure out. everythings working fine. then for no apparent reason i lose almost all my hot water pressure at the kitchen sink. the pressure is fine in the rear bathroom, but not so at the kitchen sink. what's going on? any clues would be of great help.
happypill is offline   Reply With Quote
Old 12-05-2009, 06:12 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Piece of mineral or corrosion deposit from the heater has gotten into the line and is impeding the flow?
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-06-2009, 05:13 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Take the bubbler/strainer off the end of the spigot. You will find it completely clogged with scale.
Zep
Old 12-06-2009, 09:09 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Or something's clogging the hot water side of the kitchen faucet valve assembly.
Do you have shut off valves under the kitchen sink? If yes, check the hot water shut off valve as well. It might be where the clog is.
Chris
Minno is online now   Reply With Quote
Problem with hot water pressure Namakemono Fresh Water Systems 0 09-11-2009 03:21 PM
Hot water pressure low connorsa Full-Timing 4 09-11-2009 01:11 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Low hot water pressure??? FBC72 Water Heaters, Filters & Pumps 2 07-29-2007 10:49 PM
'71 Tradewind, no hot water pressure Lumatic Fresh Water Systems 11 05-06-2007 05:29 PM
