Old 03-27-2003, 03:23 PM   #1
Post no water pressure_1990 Excella
This was to be the usual question "Hi, I don't have any water pressure when connected to city water."
I think that we found the problem, a type I am not sure has been posted before.
I read everything I found on pressure regulator prolems, thinking this was the culprit. Mike took it all apart, cleaned it, put it back.
I decided to check if we had pressure when using the water pump. The tank being empty, I started to fill it. It holds 50 gallons, so I was a bit relaxed holding the water hose: 30 seconds later, I got my first ouside shower for the year.....
The water tank was now full ! ? ! ?
If anybody with an "automatic watertank fill" switch encounters a problem with no pressure, check if that switch is not bad. Ours was off, but all that time, it was filling the tank anyway.
Mike has now to check the switch solonoid which looks like the culprit.
femuse is offline   Reply With Quote
81 excella water heater nightowlhooter1 Water Heaters, Filters & Pumps 6 08-20-2003 08:52 AM
water system mystery garymacf Plumbing - Systems & Fixtures 4 06-21-2003 11:50 AM
where are water drain valves/1990 Excella 32' ? femuse Plumbing - Systems & Fixtures 3 04-28-2003 09:13 AM
Accessing water pump on a 94 Excella John Water Heaters, Filters & Pumps 2 12-08-2002 02:44 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
