Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 05-16-2018, 05:41 PM   #1
Athens , Georgia
No water pressure with tankless heater
I replaced our water heater with a tankless and now I have no water, not even cold for some reason. This makes no sense to me. Any suggestions would be more than appreciated. The water worked for about a minute then no more water came through. Pump will turn on for a few seconds and I hear the heater clicking on but then nothing.
fresh water is attached with a T adapter to provide cold water to the heater and the rest of the trailer. The output simply runs to the faucets. I am using water tank with a brand new pump that worked just fine with the original 1972 6 gallon heater for 1 day until the tank burst.
Thanks!
Thomas
trailerparkk is offline   Reply With Quote
Old 05-18-2018, 09:13 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Could you post make and model number for the water heater?
With no flow the water heater will stay off.
Did you try and bleed off any air in the system?
sgschwend is offline   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Tankless water heater FC54 Water Heaters, Filters & Pumps 20 10-27-2004 03:18 PM
Just arrived! (tankless water heater) Morning Dew Water Heaters, Filters & Pumps 9 05-25-2004 08:37 AM
tankless hot water heater imeynstein Water Heaters, Filters & Pumps 19 04-17-2004 01:58 PM
Tankless water heater spinolio Water Heaters, Filters & Pumps 3 12-21-2002 09:53 PM
