Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Prev Previous Post   Next Post Next
Old 08-11-2009, 03:14 PM   #1
RichHog's Avatar
Profile:  1972 25' Tradewind
Houston , Texas
No water at sink when using internal pump/tank
Just got back from camping in Colorado and didn't have any water at site. So we filled the fresh water tank and turned on the pump. It whirled, gurgled and we had water in the back bath faucet (hot and Cold) and plenty in the toilet. I had also put a cap on the inlet connection as I suspected a problem with the inlet regulator. Sink water both hot and cold just gurgled and didn't flow. It works fine when I am connected with a hose. Tried changing valves under the sink but didn't work any better. Any thoughts? Also isn't the pump supposed to come on and off as it is needed once switched on? It ran continously once switched on at the panel? 72 Tradewind.
RichHog is offline   Reply With Quote
Water Pump under Kitchen sink Airdaddy Water Heaters, Filters & Pumps 8 10-29-2009 10:05 AM
Replacement Pump for pressurized water tank muddy_hollow Fresh Water Systems 23 03-03-2009 09:24 AM
HELP! Hooking up tank/pump/sink Jephellis Fresh Water Systems 0 08-13-2008 08:33 PM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 08:00 PM
pressurized galvanized tank vs. water pump 59er Water Heaters, Filters & Pumps 12 05-03-2005 04:58 AM
