Old 06-18-2014, 07:59 PM   #1
1971 27' Overlander
vista , California
No Hot Water Please Help
I have a 1989 Excella. The water heater lights and stays lit for a decent amount of time. A half or so. When I turn on the faucets on the hot water side no water comes out. This is through-out the airstream, kitchen and bathroom. When I use the valve near the water heater to divert the water cold water comes out of the hot water side. I know there is hot water in the tank I just can't get it to come out of the shower or faucets. Do you have any ideas on how to fix the problem?
jgermano is offline   Reply With Quote
Old 06-18-2014, 10:26 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Got a picture of your water heater bypass valves? That might help us answer your question. Typically, there are either two or three valves to bypass the water heater. Both, or all three, need to be in the correct position to get water both into and out of the water heater. I suspect that one of the valves is in the wrong position.
Chris
Minno is online now   Reply With Quote
Old 06-18-2014, 10:31 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It sounds like you have valves used to bypass the water heater (when winterizing) and you do not have the valves in the correct position for summer time use.
Follow the hot and cold water lines out of the water heater. There will be a valve on each of these lines. They should be open. There is a 3rd valve that connects the hot and cold water lines together. This valve should be closed for summer time use.
Old 06-19-2014, 07:17 AM   #4
1971 27' Overlander
vista , California
There is only one big silver and blue valve. When I get a chance I will post picture. If this helps I tried it in both positions and still no luck.
Old 06-19-2014, 07:40 AM   #5
1971 27' Overlander
vista , California
Here is a picture of the valve.
Old 06-19-2014, 07:43 AM   #6
1971 27' Overlander
vista , California
Trying Again...
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
No hot water, please help with some advice gowiththeflo Water Heaters, Filters & Pumps 19 07-06-2010 10:27 AM
Lost. No hot water please help. hlpnktzjr Water Heaters, Filters & Pumps 5 05-29-2009 11:42 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
