Old 08-08-2015, 06:34 PM   #1
2015 30' Classic
Hollandale , Wisconsin
No cold water in kitchen sink
We have had our new 2015 Classic out a few times now and we don't always run the water heater and leave it on. This last trip we did leave it on and we realized that we have no cold water option in the kitchen sink. Are we doing something wrong, or could something not be connected properly? The water is scalding hot and you can't cool it with any cold water. Any tips for us on this?
bjmiess is offline   Reply With Quote
Old 08-08-2015, 06:43 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Check to make sure your bypass valve is closed. Look in your water heater compartment. If it is like mine you will see two pipes coming to and going from the water heater with valves in the input side. Those valves should be open, i.e the handles should be in line with the pipes. There is also a cross pipe with a valve in it connecting the hot and cold pipes. That valve should be off, e.g. the handle should be perpendicular to the pipe. If it is open the hot and cold water will mix.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-10-2015, 01:07 PM   #3
2015 30' Classic
We think we have solved the problem. Under the sink there is a cold water valve where a filter can be installed. It was not open, so now it should work. We haven 't heated up the water to test it yet.
Heat Pump - How cold its too cold? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-09-2014 06:03 PM
Air in the kitchen cold water line CMSmith Our Community 2 05-26-2012 09:32 PM
Shower grey water reflux from kitchen sink jordandvm 2002 - 2005 International 12 12-17-2011 02:10 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
not enough hot water from kitchen sink faucet codybear Fresh Water Systems 3 01-24-2006 10:20 PM
