Old 09-02-2014, 03:01 PM   #15
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I'll check it out soon for sure!
PharmGeek is offline   Reply With Quote
Old 09-02-2014, 03:09 PM   #16
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Also, if any air is getting in on the suction side of the pump, there will also be a tendency for the piping to make a racket. Jim
Jim Flower is offline   Reply With Quote
Old 09-03-2014, 04:24 PM   #17
Charlottesville , Virginia
Thanks so much everyone!! We love the wealth of information offered at airforums!! We solved the problem by getting the air out of the hot water heater - opened spigots, turned water pump on - that was it. ahhhhh.....so much better
annedfriend is offline   Reply With Quote
Old 09-03-2014, 11:56 PM   #18
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Our water lines start knocking really abnormally loud once in a while. For us, the water pump is secure and there seems to be no undue vibration at the pump itself.... so I've determined it's air in the water lines. Since air gravitates to the highest point in the sytem, I turn off all the water faucets, lay the shower head in the shower stall (or — if we are dry camping — into a dish pan that I then dump into the toilet) and run water through the shower for a while. It may take a couple of times doing this but it always works to get the air out.
TB & Greg and Abbey Schnauzer
#3954
Old 09-04-2014, 05:44 AM   #19
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I fiddled some with it last night - think I got am some air out of hot water lines but I still think I have some - it's most notable when I use the toilet water fill/flush
I'll need to try the shower longer and I did not so the outside shower so maybe that's it
Old 04-22-2015, 09:44 AM   #20
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
I had an SOB for 15 years and the pump noise was a known quantity. My new '15 CCD pump seems louder. It is not the typical rattle sound but the revving sound and the water output is fast then slow.......
Is that a normal behavior?
Is that the "beauty of the variable speed pump?
This is our third trip out. Normally we are full hook up folks. But, I set up on the pad one foot further than my fresh water hose would tolerate! I decided that we could tough it out for the night.
DoublTrouble is offline   Reply With Quote
Old 10-15-2016, 11:18 AM   #21
TinVenture's Avatar
2016 19' International
Orange County , California
How exactly do I bleed the lines? I too am having the same problem in my 19' Bambi. At low speeds the water pump sounds like a jack hammer. Is there a valve I need to open under the dinette seat where the pump is located? I remember seeing drain valves near the water heater under the bed also?
www.TinVenture.com
Instagram: TinVenture
TinVenture is offline   Reply With Quote
Old 10-15-2016, 01:09 PM   #22
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
TinVenture, Check out these threads.
http://www.airforums.com/forums/f443...-148414-3.html and
http://www.airforums.com/forums/f445...ml#post1862579 that are recent comments.
I made some mods referenced in the first thread and happy with the improvement. I believe much of the noise as the late IDROBA indicated are due to the elbows and other connections banging on the floor or diamond plate. I still have some shuddering but it sounds like it is under the shower, so I'm done and have moved on.
Good luck
bob
CruizinDux is offline   Reply With Quote
Old 10-15-2016, 01:43 PM   #23
TinVenture's Avatar
Good luck
bob
Thanks for the links. Looks like a lot of good info!
Jon
www.TinVenture.com
Old 10-15-2016, 02:02 PM   #24
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I am not sure about the variable pumps but there are options to quiet the pumps. I have used the water pump quite a bit and the shure-flo quieting kit does help. Before the wall/water lines vibrated every time the pump pressurized the lines- two seconds-then again. Now you can hear the pump run but without the wall vibrations quieting the use down.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 11:18 AM
water pump noise Josie28 General Repair Forum 7 10-23-2012 10:52 PM
Interstate 3500 2012 water pump noise TY PECK Plumbing - Systems & Fixtures 4 03-09-2012 10:05 AM
Water Pump Noise dkekrksk 2002 - 2005 International 11 01-04-2008 08:41 PM
Water Pump Noise pmclemore Water Heaters, Filters & Pumps 14 05-09-2006 02:06 PM
