Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 05-26-2012, 03:10 PM   #1
L911's Avatar
1971 18' Caravel
Cookeville , Tennessee
Images: 12
Newbie - Plumbing on 1970 Ambassador
My new 1970 Ambasador has a leak somewhere in the plumbing i'm assuming, when you flip the 12v pump water pours out from under the trailer. The trailer is like a time capsule, its all original.
L911 is offline   Reply With Quote
Old 05-26-2012, 04:02 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
Welcome!
If I were the buyer, that'd be good news. It probably means it was winterized and a drain valve (or two, or three) is open.
On the other hand it might be bad news and mean it was never winterized and everything froze up and will need replacing.
I think it's one or the other.
Old 05-26-2012, 04:37 PM   #3
L911's Avatar
1971 18' Caravel
Images: 12
Plumbing repair
Well, its not good news. I attached the garden hose to it, closed a rear drain & water is coming from under the bellypan. The floor under the fresh water pump has a trickle of water coming from somewhere, but thats not the big leak. I'm not getting any want out of any faucet. I do hear water running into the hot water heater. It sounds like the leak is under the belly pan in the rear somewhere. I'm not getting water from the freshwater tank either, although you can hear it pumping what sounds like water & air.
Old 05-26-2012, 05:07 PM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
You got to find the leaks. I do not know the layout of your trailer. You need to start with the inlet and work along the lines until you find the leaks. On ours the inlet is under the bed and the pump is under the floor of the closet. The lines run across the trailer under the floor. The fresh water tank has to be filled separatly on most Airstreams. There is a check valve between the pump and the plumbing outlets that let the pump move water to the faucets, but does not let the water flow back through the pump and into the fresh water tank. The pump is a suction lift so if there is a leak in that line it gurgles and will not pump. Sounds like you have a broken line. The low point drains should have hoses that extend below the belly pan. All of us have had leaks. Probably time to start reviewing the posts on PEX. Sounds like you will have some PEX in your future. What kind of plumbing do you have now? Copper? Grey tubing? Freezing is just devastating to copper lines. Ditto PVC. Grey tubing will take some freezing, but the fittings tend to get brittle and break. My trailers are now a combination of grey tubing and white PEX. I carry the little crimping tool, some fittings, and a length of tubing in the trailer storage compartment. The bad news is that all many of the lines are hard to get to. The good news is that the PEX is easy cheap and easy to work with and you can sometimes snake it through with out dismantling everything or even removing the old line. you can buy an adaptor that lets you hook an airline to the water inlet. get one. you will need it to winterize anyway. You might be able to locate the leak without getting the trailer any wetter by blowing air in the lines and looking for where it is coming out.
Old 05-26-2012, 05:22 PM   #5
L911's Avatar
1971 18' Caravel
Images: 12
Thanks, i followed the copper lines along the left (drivers) side of the trailer to the hotwater heater (its in a closet beside the toilet) i didnt see any leaks there. It appears to me there must be a leak under the shower stall or under the floor of the rear side bed (door side). Ive owned 3 Airstrems & never seen a trailer laid out quite like this one from the factory. Its all original & looks like every option, lots of closets & cubby holes. Actually its overwhelming. Its a 1970 Ambasador.
Old 05-26-2012, 05:27 PM   #6
1988 25' Excella
1987 32' Excella
I rate that as good news. Maybe you are just dealing with one broken line or fitting rather that freeze damage.
Old 05-26-2012, 06:21 PM   #7
WineStream's Avatar
2023 30' Globetrotter
Pleasanton , California
Images: 24
Mine had a pipe burst under the shower / tub. You've got to remove the upper cover of the shower to see the pipes running under it. Once you can see down in there, then you can determine if / where the leak is in there.
WineStream is offline   Reply With Quote
Old 05-26-2012, 06:49 PM   #8
Splitrock's Avatar
My trailer had 5 drain valves for winterizing in addition to the water heater drain. When I added pump pressure the water ran on the ground near the rear. There was a pressure pop off valve stuck open.
My copper water system was all good but it was removed as a part of installing new cabinets, faucets and a new water heater. I saved the inlet and the cross over. The rest I replaced. I used braided plastic and hose clamps to tie into the shower faucet.
When I added city water pressure, nothing happened. The backflow preventer was clogged with debris.
Old 05-26-2012, 07:03 PM   #9
Splitrock's Avatar
Actually the water ran on the ground from the belly pan in the rear. I feared the worst . . . but the drain hose had come off the pop off valve stem. I removed the pop off valve, cleaned it, reset the spring valve and reinstalled the hose.
I replaced most all of the plumbing with pex. I tested my work with air and it held pressure, but I have yet to test it with water.
Old 08-25-2012, 04:39 PM   #10
gmcryan's Avatar
1984 31' Sovereign
Edmond , Oklahoma
Can the entire plumbing lines be changed without having to remove the floor or belly-pan? I'm in the process of switching the poly lines over to Pex. I was moving right along with my installation until I noticed a line making a 90 degree turn down into the floor. In my opinion, I think this line goes from the water pump the kitchen sink (both are located on opposite sides of the trailer). To be more specific, one of the water lines from the kitchen sink tees. One of the lines goes towards the bathroom and the other goes under the floor. Can I fish the new Pex through the floor by disconnecting all fittings and then connect the old poly to the new Pex? Basically, I want to pull the old poly out and hopefully the new Pex will be pulled into place. Is this just wishful thinking? It seems like every "day project" I start ends up taking weeks/months. Any advice would be greatly appreciated. Thanks, Ryan
gmcryan is offline   Reply With Quote
Old 08-25-2012, 04:52 PM   #11
Splitrock's Avatar
My trailer had one crossover under the floor. It was good and I left it in. I connected pex to one end and braided hose to the other.
I believe I could have pulled braided hose under the floor without removing the pan, but not pex.
I like copper. I have no issues with leaving a good section.
Old 08-25-2012, 08:37 PM   #12
gmcryan's Avatar
1984 31' Sovereign
Edmond , Oklahoma
I will probably end up keeping the piece of poly for the time being. I've heard bad things about this type of pipe. I need to look into the braid that you are talking about. Sometimes the "more flexible" PEX is even difficult to bend. Thanks for the advice!
Old 08-25-2012, 09:03 PM   #13
rogerdodger's Avatar
1974 Argosy 28
Fresno/Clovis , California
All the copper had white water hose and clamps as repairs. I have pulled out all the copper, replaced with pex. The lines from the cold/hot run behind the rear bath and up the curbside past the wheelwell to the kitchen. No lines under the floor. It can be done!
Roger
rogerdodger is offline   Reply With Quote
Old 08-26-2012, 06:57 PM   #14
WineStream's Avatar
Images: 24
Unless someone has done something funky after the factory, I don't know of anything that should be under the floor. There should be low-point drains for the cold and hot water circuits at the galley area and near the city water inlet. I've never seen drains be a 90, only a T; but they COULD be a 90...just I've never seen it. I assume that near this T and/or 90 that goes through your floor there is a valve? If so, then this is your low-point drain. Have a look under the trailer right about where the pipe goes through the floor inside and I'll bet you find a stub of pipe sticking out the bottom of the trailer.
Old 08-26-2012, 08:20 PM   #15
gmcryan's Avatar
1984 31' Sovereign
Edmond , Oklahoma
So far, I like what I hear! I assumed the pipe runs under the floor because the water pump and city water hookup are on the opposite side of the bathroom and kitchen. I have a service manual, but it is quite difficult to interpret. Thanks for the help.
Old 08-26-2012, 08:52 PM   #16
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
The first item on my aggenda would be to identify if the leak is in the cold water piping or the hot water piping (or both). Close the valve at the water heater or just install a plug if there is no valve. If it is still leaking you have a leak on the cold water side. Now find the leak by following the cold water line. Most piping I have seen is not uder the floor. If I had any copper or gray polybutylene, I would remove it and replace it with Pex. Heck, this trailer is 40 years old. If you are working on the plumbing you may as well change it all to pex. It is not that big of a deal. Pex is easy to work with. The problem with pb piping is that fittings are no longer available; all you can do is install an adopter to go from pb to pex.
Good luck, dan
Old 08-27-2012, 02:21 PM   #17
L911's Avatar
1971 18' Caravel
Images: 12
Plumbing Diagram
Where can I get a plumbing diagram for my 1971 Ambassador? I thought i had all the leaks stopped, but i must have some mystery pipes under the bellypan or in between the floor somewhere.
Old 08-27-2012, 05:07 PM   #18
WineStream's Avatar
Images: 24
A service manual for your trailer will show the intended factory installation. If someone has done something custom in the 39 years of your trailer's existence, then the manual won't help you. I have the manual for 1974 and it covers the Ambassador chassis. I'd be happy to photo the page and post it here if you'll tell me if you have the center or rear bathroom.
It would be helpful if you could tell us where the water is coming from on the trailer. Rear street side? Under the galley? Front curb side? Is it gushing? Is it dripping? On city water or only when on the pump from the fresh tank? Do you see the leak inside the trailer (wet carpet or subfloor) or outside?
Something that I was reminded of when reviewing my service manual is that there is a overpressure valve. This kinda looks like a 90 degree fitting with a knuckle on it. It is near the factory regulator and city inlet. If the valve itself or the regulator fails, it would dump water out of the bottom of the trailer. This is where the location of your water leak would be helpful to know.
Old 08-27-2012, 06:24 PM   #19
L911's Avatar
1971 18' Caravel
Images: 12
Scan
Yes, thank you! I ve been planning on replacing the water valve you mentioned. Im planning on installing a new water inlet & pressure regulator from camping world. I'm getting a leak below the rear waste tank all clear water & not all the time either. Also the shower has almost no pressure, i think thats the shower control valve though.
Old 08-27-2012, 06:34 PM   #20
WineStream's Avatar
Images: 24
I still need to know which floor plan you have in order to upload the right picture.
