Old 10-22-2012, 08:44 AM   #1
jornvango's Avatar
Newbie alert: how to hookup the water hose
We bought our '95 Sovereign (21ft) last week. We just took it out for a first weekend trip yesterday. We went 'boondocking' and made it through the weekend without major issues and a lot of reading in the manual.
Now that we're back home, I tried to fill up the water tank. The AS came with 2 hoses, both of which I assume are for drinking water.
Here's what I tried to do:
1) open the plug on the outside of the AS
2) hook up the hose -> Problem: the hose doesn't have an adapter to hookup to this ... so either I'm truly missing an adapter or I'm doing something wrong (my money is on the second one).
See the attachments for a picture of where I'm trying to hookup the hose, and a picture of the 2 hoses.
Can you help a newbie out?
Am I even looking at the correct hookup or is the 'city water hookup' (next to the electrical hookup) where I refill the water tank??
Thanks!
ID:	171047   Click image for larger version
ID:	171049   Click image for larger version
jornvango is offline   Reply With Quote
Old 10-22-2012, 08:50 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
What you are seeing is the spout to fill the water tank, not the connection for city water. Look for a female hose adapter on the trailer. Mine is in the read, but it is much older.
Richard
Old 10-22-2012, 08:50 AM   #3
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
to add water to your tank you need that water fill hose from camping world
http://www.campingworld.com/shopping...nk-fillers/594
LilNomad
LiLNomad is offline   Reply With Quote
Old 10-22-2012, 09:01 AM   #4
jornvango's Avatar
Thanks. It seems like we're missing the water filler hose; I'll order that.
What is the difference between this tank and the connection for city water at the bottom of the AS? When hooked up to city water, does it bypass the AS tank?
Old 10-22-2012, 10:21 AM   #5
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
City water or "Shore Water" does bypass the fresh water tank. Another trick; if you find the shore water pressure low, you can turn on your pump and supplement water from your fresh water tank to increase the pressure a bit to, for instance, the shower head. Have fun learning and don't hesitate to ask here. Congrats on the new trailer.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 10-22-2012, 03:38 PM   #6
jornvango's Avatar
Thanks! That's another thing I didn't think about: when plugged into shore water, we don't need to run the water pump (unless as you say, pressure is really low).
Old 10-22-2012, 04:39 PM   #7
mefly2's Avatar
2015 25' FB Eddie Bauer
Yes ...
Old 10-22-2012, 05:00 PM   #8
Zia
2011 23' FB International
2007 20' Safari
Irvine , California
I prefer not to hook up my fresh water tank inlet with threaded fitting, the chances of over filling or air gap are higher. Just insert the hose in the tank inlet hole and fill the tank. If you try to fill too fast sometimes the air gap in the pipe is created which stop the water going into the tank and start gushing out like the tanks is full when it is not
Welcome to the forrum
Zia is offline   Reply With Quote
Old 10-22-2012, 05:04 PM   #9
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Here's What I Use...
Everyone should have one in their "Blue Bag"
Name:	Camco Filler.jpg
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-22-2012, 05:28 PM   #10
2011 30' Flying Cloud
Arvada , Colorado
The water fill hose we too purchased from Camping World worked great UNTIL the water pressure separated the clear hose from the cap and of course, it went down into the tank. Suggest a clamp be used.
Jack46 is offline   Reply With Quote
Old 10-22-2012, 08:13 PM   #11
dznf0g's Avatar
Oswego , Illinois
I have never used the Hose thingy. I just stick the hose into the fill port. Yes, occasionally it will pop out if the water pressure is high, but it has never been such an issue to prompt me to spend the $ and the extra step to fill.....and I have most ALL the gadgets.
-Rich-
