Old 11-14-2013, 04:10 PM   #1
2013 30' Flying Cloud
Amarillo , Texas
New trailer home, can't figure out water pump issue...
Alright,
Just got my beautiful new 2013 Flying Cloud FB home. I've had her for about 24 hours and have been learning/working all the systems. Everything is great so far except my water pump. It runs and in the lavatory the hot side will run a low, steady steam of water, but the cold side will sputter. In the galley both sides sputter. The last few times I ran it it clicks for a few minutes after I turn it off.
Another note about this: I called the dealer tech who had told me when we were walking through that I needed to take a couple screws out from under the lavatory sink and lift up on the board that makes the bottom shelf. He said under that is a valve that they had activated to keep water from running through the trailer while in storage. I had forgotten he told me that so I happily unscrewed four screws from that shelf today, thinking I was about to solve my problem.
Well, the shelf will NOT budge! It even looks like in the gap that there are wooden dowels holding it in place. It doesn't seem like it was made to easily access anything, and I don't want to break this shelf. The tech told me to bring the AS in but I really don't want to do that right now, as I'm all settled. I found the actual pump right next to the lavatory seat behind some galley drawers, but don't see the problem.
Any ideas besides hauling this thing to the dealer?
txairdream is offline   Reply With Quote
Old 11-14-2013, 05:00 PM   #2
kswelsh's Avatar
2012 30' Classic
Wildwood , Missouri
Dumb question - is there enough water coming up from the fresh water tank or outside hookup to support the use of the water pump?
kswelsh is offline   Reply With Quote
Old 11-14-2013, 06:19 PM   #3
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Did you read your owners manual? Airstream has great manuals. It is well worth the time it takes.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 11-14-2013, 07:29 PM   #4
Amarillo , Texas
I have a full fresh water tank, and I did read the owners manual. Perplexed.
Old 11-14-2013, 08:04 PM   #5
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I am of no help...but just letting you know I feel bad for you, it is these small thing that can just drive us nuts, more because we r learning something new. Keep a little running comentary in a notebook everytime something comes up...good to reference. I hope it works out easily for you and you enjoy your Airstream forever.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 11-14-2013, 08:10 PM   #6
2012 30' Classic
Homosassa , Florida
I would call A/S customer service. They are very helpful and can probably help you figure it out quickly. I'd call them on the cell so you can look at whatever they describe as the correction in real time.
Tater is offline   Reply With Quote
Old 11-14-2013, 08:29 PM   #7
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
You need an Airstream buddy.
Suggest you start a new thread with your city in the title asking for help understanding the workings of your Airstream. I would not drag it back to the dealer he has already done you a disservice.
There are a good many WBCCI members in Amarillo. Someone will help.
I would if you were in Albuquerque.
Ken L
1966 Tradewind 24
Old 11-14-2013, 09:01 PM   #8
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Where is your pump located? It sounds like air in the lines, if your water heater is closer to the pump than the kitchen sink it would fill with water first. Also does water run through everything when hooked to the city supply?
Gary
Castaway is online now   Reply With Quote
Old 11-14-2013, 09:07 PM   #9
SkooterPop's Avatar
1973 Argosy 26
Chandler , Arizona
I don't know anything about a shelf, as my Argosy is ancient and they probably didn't use shut off valves at that time, but sputtering in water spigots sound like air in the lines to me. I would check for leaks under cupboards or anywhere else fresh water lines run and if you don't see or feel any water where it shouldn't be, try to power up the pump and let it run a while with the taps open to see if the sputtering turns into steady streams. Another thing I would try is to do the same checks with fresh water from an outside supply hose hooked up.
“The whole aim of practical politics is to keep the populace alarmed (and hence clamorous to be led to safety) by an endless series of hobgoblins, most of them imaginary.”
H.L. Mencken
SkooterPop is offline   Reply With Quote
Old 11-14-2013, 09:07 PM   #10
Amarillo , Texas
Great suggestions, y'all. Will call customer service tomorrow. Haven't tried city water yet, I need to get to a local rv park to try the connections. I will let you know what I find out!
Old 11-14-2013, 09:30 PM   #11
daveswenson's Avatar
2012 28' International
Issaquah , Washington
You don't need to go to an rv park to test the city water connection. If you have a faucet you can attach a hose. It really sounds like you just have air in the lines. If you open up your faucets and let it run, you should clear out the air.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 11-14-2013, 09:32 PM   #12
Amarillo , Texas
Well let's just put it this way - I wanna go to an RV park because I'm excited to get this thing out there, lol! And yes an rv park excites me at this point
Old 11-14-2013, 09:53 PM   #13
aftermath's Avatar
Spokane , Washington
Could it be that you have a bypass at your water pump that allows you to winterize the trailer directly from a jug of antifreeze? I had one of these on my earlier SOB and if the valve was left open it would suck in air instead of water from the tank.
I can't imagine any other valve as you described. Please let us know how this all works out in the end.
aftermath is offline   Reply With Quote
Old 11-22-2013, 03:00 PM   #14
Amarillo , Texas
Ok, so I finally had time to take it to the dealer and they fixed the problem! Here was the deal: first of all, the access to the pump was NOT under the sink as they had told me but rather under the drawers in the galley. Then the tech found a filter screen that was not screwed on tightly. That fixed it - my water pump works like a dream now. They really should have caught that when they prepped the trailer!
