Old 08-26-2015, 03:22 PM   #1
1979 28' Airstream Excella 28
Brooklyn , New York
New monitor system
I want to put a new monitor system in my 79 excella motorhome. What are the best ones out there? How easy is it to tap into the wiring for the tank sensors?
Walkietalkie is offline   Reply With Quote
Old 08-26-2015, 07:53 PM   #2
Mixter's Avatar
1976 27' Overlander
Do a search for See Level. Lots of info on it.
Mixter is offline   Reply With Quote
Old 08-26-2015, 08:10 PM   #3
Brooklyn , New York
Does the See Level have battery system monitoring as well?
Old 08-26-2015, 08:13 PM   #4
Brooklyn , New York
Also, how do the tank monitors in my 1979 Excella motorhome function? Meaning, are there floats internally or are there sensors on the outside?
Old 08-26-2015, 08:43 PM   #5
Mixter's Avatar
1976 27' Overlander
See Level will tell you voltage. https://www.garnetinstruments.com/rv-shop/products/
You can get into extensive battery monitoring with something like the Trimetic. Trimetric TM-2025-RV Battery Monitor System
Your current monitoring is by way of stainless probes at different heights in the tank. Voltage is transmitted through the water to determine level. The reason they fail is because of sludge or debris on the probes prohibits reliable completion of the circuit.
The See Level system works from the outside of the tank by sensor strips that you stick on. You can use the same wiring from the probes to hook up the See Level.
I have not yet installed this system, but I will be. The reviews that I have read have all been favorable and sounds like they are consistently accurate.
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
Tank monitor system on the fritz mhilley Fresh Water Systems 7 11-27-2011 08:57 AM
System Monitor - Micro Plus ASchwager Plumbing - Systems & Fixtures 1 05-22-2011 08:06 PM
System Monitor vs. Reality (black water)! tomorevam Waste Systems, Tanks & Totes 7 05-14-2011 02:59 PM
Upgrade to a new system monitor? GoNomad Electrical - Systems, Generators, Batteries & Solar 7 10-27-2006 07:02 AM
