Old 11-11-2015, 08:42 AM   #1
1975 25' Tradewind
dallas , Texas
New Fresh water tank installation
I have a 1976 Tradewind LandYacht which i love. I am full timing and i have done a ton of restorations while i travel.
I am debating as to whether or not i should complete the following replacement on my own or hire someone while in AZ this winter.
I need a new fresh water tank. There is a leak, a really bad leak, so i need to know what size tank and hopefully i can get some help or do it on my own.
It is one of the final projects i need to complete until the trailer is complete.
Has anyone completed this project and if so are there any images.
hippygypsy is offline   Reply With Quote
Old 11-11-2015, 08:52 AM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Find the tank location and gain access to the area (inside cabinet, under gaucho, etc). Either measure tank or find a label indicating dimensions and/or manufacturer. If it is not a custom tank you can probably get a replacement. Hopefully the trailer was not built around it :-)
BambiTex is offline   Reply With Quote
Old 11-11-2015, 09:20 AM   #3
1973 25' Tradewind
Beautiful , Oregon
I believe there are exact replacements available from AS dealers. I have not kept up buy INland RV had them
I pulled mine out on a 73 Tradewind and clean it up, tested and reinstalled. I believe yours would be the same.
They are held in with some framing under trailer one bar is removable. It sits on a piece of 1 1/8 inch plywood that is covered by a sheet of aluminum. I got it out by attaching a large eyebolt in it and attaching a come along and working it out. I will post pictures when I get home tonight
Tony
Tony S is offline   Reply With Quote
Old 11-11-2015, 09:53 AM   #4
1986 31' Sovereign
Miami , Florida
JD Sanders in Alachua ordered me up a new fresh water tank for my 1986 Sovereign. Worth a call to you friendly neighborhood dealer...
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 11-11-2015, 10:29 PM   #5
1973 25' Tradewind
Beautiful , Oregon
Here are some pictures, I hope. come along pulling plywood out,
plywood on way out, tank being held up by buckets, fresh water tank ready to clean out, Varnished plywood, new belly pan aluminum
Hope it helps
Tony
ID:	251951   Click image for larger version
ID:	251953   Click image for larger version
Old 11-12-2015, 09:35 AM   #6
Mixter's Avatar
1976 27' Overlander
tallredboned might be facing same issue I had...
My '76 Overlander had the tank with the open square cutout in the middle (like a square donut) for a different style mount. I believe '75 was the last year of the 1" plywood shelf that slides out. In '76 they went to a galvanized pan bolted around the perimeter, with a big square plate that bolts up and holds up the middle.
My tank was also badly cracked. I dont recall that I could locate that style of tank either. Even if I "could" find it, the galvanized pan was disintegrated with rust. Fab'ing up a new pan would have been a chore in itself because of the design.
I found that the pre-1976 tank as shown above, is one that you can still find and buy new, as it looks to still be in use on a bunch of other models as well. (It may be on the '80s as stated above?)
I happened to stumble across a used one that was clean and I fabricated up the mounting style of the pre-1976 with the 1" plywood shelf. It was a pretty big job, but I did a shell off and did a bunch of metal work to the frame so it was easier. It could be done from underneath, but I can imagine it will be costly.
ID:	251965   Click image for larger version
ID:	251967   Click image for larger version
ID:	251969   Click image for larger version
ID:	251971   Click image for larger version
Mixter is offline   Reply With Quote
Old 11-17-2015, 08:14 PM   #7
1975 25' Tradewind
dallas , Texas
Thanks for the advice.
It does not look like a complicated job. Just a bit laborous.
I think my tank is like the overlander.
But now i need yo find a new one.
Thats the first item.
Old 03-21-2016, 04:47 AM   #8
Los Gatos , California
If your tank is leaking, then the only solution is its replacement. I think water tank once start leaking have no repair option, you need to call an experienced plumber for proper water tank Installation.
kwick is offline   Reply With Quote
Old 05-22-2016, 12:59 PM   #9
1975 25' Tradewind
dallas , Texas
Does anyone know a repair place in Philadelphia?
Old 05-22-2016, 01:57 PM   #10
2011 27' FB Classic
Camp Hill , Pennsylvania
A good repair place near Philadelphia is Colonial Airstream in Lakewood NJ. Perhaps an hour away.
LyleRussell is offline   Reply With Quote
Old 05-23-2016, 08:12 AM   #11
1975 25' Tradewind
dallas , Texas
Anybody know of a realistic place near philly to get this done?
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
New Fresh Water Tank Installation airdoxy Fresh Water Systems 0 07-09-2010 08:30 PM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
