Old 09-20-2015, 10:49 PM   #1
2004 22' International CCD
Kansas City , Missouri
Need Replacement Faucet for wet bath 2004 22 ft International
We have a 22 ft 2004 International and on our first day of a trip to Alaska the bathroom faucet began leaking and we could not get it to stop. I have researched it and it seems that faucet is prone to this. The manufacturer of the faucet no longer makes it. Is anyone aware of a good option to replace that faucet with one that has a pull out sprayer to support the shower but still fits in the space.
thank you
Lee & Ellen
LWPittman55 is offline   Reply With Quote
Old 10-04-2015, 01:27 AM   #2
2015 30' International
Box Elder , South Dakota
I had the exact same problem, and had to find something I'd love on short notice. I bought this faucet, and absolutely love it. The shut-off control is only intermittent -- meaning you need to keep the button held down to stop the flow. So I use that when it's handheld, but for longer pauses, I turn off the water at the faucet. Which is easy since it's a single mixer control. Note that this comes in regular and "bar sink" sizes. You want the bar sink size which is a 7" overhang.
KOHLER | K-7506 | Purist Single-Handle Pullout Spray Bar Sink Faucet
KOHLER K-7506 Purist Secondary Single-hole Kitchen Sink Faucet with 7-inch Pullout Spout - Overstock Shopping - Great Deals on Kohler Kitchen Faucets
lbdesign is offline   Reply With Quote
Old 10-04-2015, 01:37 AM   #3
Old 10-04-2015, 10:15 PM   #4
BTW, after I bought this, I found out about another manufacturer who makes some faucets specifically for wet baths. Just make sure their wide designs have sufficient clearance in the corner of the sink.
Scandvik Marine Inc. - list
I have exactly your model -- 2004 22' CCD, so I understand the space issues. And BTW, installing the faucet is a pain through that little access panel. Make sure whoever does it does not cheat and damage the fittings under the faucet housing because s/he can't get both arms in there to stabilize the feed lines while tightening the connections. If the job is rushed, you could end up with a hidden leak.
Old 10-05-2015, 09:40 AM   #5
Thanks for the information on the faucet and the installation challenges. I was going to do it myself but room is very tight in there.
Lee
Old 10-05-2015, 10:18 PM   #6
Yes, I didn't want to do it myself for the same reason —*that it's so cramped in there. So I let a factory-trained tech at an Airstream dealer do it, and he bungled the install. I had to have someone else replace it with the faucet pictured above! Good luck and enjoy your 22'. It's a great size and layout.
NEED HELP with my '72 TW wet bath jcain63 Sinks, Showers & Toilets 20 03-07-2015 08:29 PM
replacement faucet (and showerhead) for wet bath? lbdesign Sinks, Showers & Toilets 2 12-19-2014 10:34 PM
Wet Bath Mirror pulled off wall-need repair ideas rmkrum General Repair Forum 6 08-14-2013 12:43 PM
Has anyone ever converted a regular rear bath to a wet bath? tvadman1963 Sinks, Showers & Toilets 2 12-29-2006 11:15 AM
need new bath sink faucet KHarris Sinks, Showers & Toilets 3 09-05-2006 10:31 PM
