Old 08-04-2004, 05:53 PM   #1
Need HELP! Access to the copper pipe.
Does anyone know an easy way to get to the copper pipe behind the kick board at the shower entrance. See photo. I believe my second leak is right behind this board and I can't figure how to remove without having to take apart the bathroom. Any suggestions?
Name:	Shower kick board.JPG
Crazyland is offline   Reply With Quote
Old 08-04-2004, 08:33 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Remove the plastic insert in the yellow aluminum extrusion. This will allow you access to the rivets that hold the extrusion in place, and likely hold the panel in place.
That should be all you need to remove, the plastic insert, the rivets, the extrusion, the panel.
If the plastic insert snaps or breaks it is normally available from a dealer for a minimal cost.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-10-2004, 08:57 AM   #3
Got it.
Thanks for the reply. I got it off last weekend only to find more copper splits. Heading to Lowes today to look at the PEX product.
Old 08-10-2004, 10:56 AM   #4
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Oh Yes, do the PEX replacement.
Look at the type of connectors that are available a crimp ring or a compression collar type fitting will work.
I used the ones with a crimp ring because I was able to rent the crimp tool. $5.00 per day. It is a high quality connection. The compression collar works also and is great for repairs if you should have trouble down the road.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 08-11-2004, 07:35 AM   #5
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
Is the PEX able to prevent a split or damage when water is frozen in it?
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 08-11-2004, 05:26 PM   #6
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
It won't totally prevent a split but, it just will not stretch/swell out of shape like copper. Thus repairs are a matter of cutting out the section and replacing it.
It is also much easier to work with than sweating copper, provided you have the crimper. Or you can use the PEX compression fittings that tighten by hand or the plastic wrench, which is only a couple of dollars.
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 08-13-2004, 03:15 PM   #7
1972 31' Sovereign
Oakdale , Minnesota
Originally Posted by BobbyW
...Thus repairs are a matter of cutting out the section and replacing it.
It is also much easier to work with than sweating copper...
Clearly, I'm pretty green. Sweating copper hasn't been that big of a deal. I suppose this has to do with the fact that I expected it to be far more difficult than it turned out to be.
I'm also doing everything I can to maintain the look and feel of original ... plumbing seems silly, but copper pipes are not normal on new trailers (don't know about new A/S).
Mark
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
Copper pipe help Crazyland Fresh Water Systems 26 03-03-2005 06:04 PM
1950s copper pipe connections ivesterm Plumbing - Systems & Fixtures 9 10-02-2003 05:58 AM
Plumbing - A Mystery Pipe Tamara Plumbing - Systems & Fixtures 8 04-18-2003 12:56 PM
Greywater drain pipe repair davidz71 Waste Systems, Tanks & Totes 4 06-04-2002 09:39 PM
