Old 06-02-2014, 04:04 PM   #1
TetonStreamer
Teton Stream's Avatar
2017 23' Flying Cloud
Wilson , Wyoming
Need Guidance
I installed an accumulator in my 2013 Bambi (right next to the pump). Checked out as advertised. Let it sit with pump on for three days to check for any leaks. Came in today (day three), no leaks and turned on water, full pressure. As it bled off the pump did not start. Turned off power, check fuse, turned on power pump started and charged system, stopped (ever so gradually as with accumulator). Ran water again and system bled down with no pump activation. Rocked the pump switch a couple of times and pump came on. No rhyme or reason to the number or frequency of on/off's to get pump to work.
Any thoughts besides bad pressure sensor on a 7 month old pump?
Teton Streamer - in The Toaster
Wilson, WY 83014
Teton Stream is offline   Reply With Quote
Old 06-02-2014, 06:04 PM   #2
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Did it work OK before you installed the accumulator?
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 06-02-2014, 07:36 PM   #3
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Accumulators are not recommend for use with the variable speed pumps in new trailers. Take out the accumulator, it's not needed.
If you could have a superpower, what would it be?
I chose America
Bigventure is online now   Reply With Quote
Need guidance in Cincinnati nilesrob On The Road... 7 08-30-2011 08:52 PM
Need Guidance Joe O'D Member Introductions 3 06-01-2010 07:16 PM
Upgrading to New TV - Need Guidance Stephen Mick Tow Vehicles 45 11-09-2008 10:18 PM
Some Guidance nikshak General Repair Forum 11 03-15-2003 05:31 AM
