Old 09-23-2016, 05:32 AM   #1
1976 Argosy 28
London , Ontario
mystery plumbing fixture?
Hi. I've discovered the attached brass thing under the sink in our 28 C/B Argosy. Any ideas what function it serves and if it is necessary (it currently leaks under the round part at the top.
Tree is offline   Reply With Quote
Old 09-23-2016, 05:56 AM   #2
Trnpk Crsr's Avatar
Baltimore , Maryland
It's vaccum breaker/back flow preventer. What is it attached to?
John
Trnpk Crsr is offline   Reply With Quote
Old 09-23-2016, 06:49 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
It is a pressure relief valve.
If water pressure exceeds a set pressure point it discharges water through the flexible hose.
Excess water pressure can occur either from the water supply or from a malfunctioning water heater. There must be a pressure relief valve somewhere in the fresh water system. In both of my trailers the pressure relief is on the water heater.
This is similar
http://www.wholesalepumpsdirect.com/...ief-valve.html
Alan
Old 09-23-2016, 07:21 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
I vote for back flow preventer.
It would be interesting to know what it is hooked up to. They are normally at the city supply connection not within the trailer serving one function.
2004 Excursion 4x4
Old 09-23-2016, 07:50 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Some examples:
http://www.airforums.com/forums/f227...uet-69335.html
http://www.airforums.com/forums/f163...ter-94760.html
http://www.airforums.com/forums/f44/...ak-153941.html
If you can get a photo of the top of the device, there should be information there.
Alan
Old 09-23-2016, 07:56 AM   #6
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
It's a vacuum break usually attached to the toilet to keep water from feeding back into the system.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 09-23-2016, 08:10 AM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
It sure looks like this one!
Maybe I'll have to admit I'm wrong :-0
http://www.shopbackflow.com/watts/wa...vb/watts-288a/
Alan
Old 09-24-2016, 06:51 AM   #8
1976 Argosy 28
London , Ontario
It is high up under the counter top so without disassembly we can't see the top. The plastic line attached to it goes to a spray handle (for use in the toilet?). The plumbing system ends in the bathroom - so vacuum break makes some sense. But then so does a pressure reducer if the spray is in the toilet. I have to do some plumbing on the trailer next week so we may be able to solve the mystery.
Old 09-24-2016, 11:12 AM   #9
Zil
egg harbor city , South Jersey
It is incorrectly called a back-flow preventer. It is a anti-siphon valve, or what is called a vacuum breaker. It prevents a low pressure event from drawing water back into the system. It will not stop higher pressure from feeding back.
Zil is offline   Reply With Quote
Mystery Plumbing Part... bludatta Fresh Water Systems 9 03-01-2013 02:28 PM
Shower plumbing fixture harrison Sinks, Showers & Toilets 4 05-06-2011 04:22 PM
Hot Water/Plumbing Mystery - Can you solve it? mello mike Plumbing - Systems & Fixtures 12 01-26-2010 10:32 AM
replacing 12v fixture with LED fixture funkill Lights - Interior & Exterior 2 08-26-2009 10:20 AM
Plumbing - A Mystery Pipe Tamara Plumbing - Systems & Fixtures 8 04-18-2003 12:56 PM
