Old 10-14-2012, 08:11 PM   #1
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Unhappy My grey water tank fills when I turn on city water
I bought a 2013 Classic Limited 30 Friday, and took it to a campground Saturday. I hooked everything up the same way I did my previous Forest River Wildwood 28RLSS trailer. When I turned on city water, the grey water tank filled and no water would come from any faucet. What am I overlooking?
Old 10-14-2012, 08:17 PM   #2
dznf0g's Avatar
Oswego , Illinois
There is a check valve in the water pump to prevent that. Sounds like a warranty trip to the dealer for a new pump. I would think you'd get a dribble out of the faucets though.
Wait! gray tank or black. Are you hooked up to the black inlet or the white inlet in the outside compartment?
-Rich-
Old 10-14-2012, 08:21 PM   #3
dznf0g's Avatar
Oswego , Illinois
I think you are hooked up to the black tank flusher.
-Rich-
Old 10-14-2012, 09:13 PM   #4
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Welcome to the forums.
Sounds like you have hooked up to a tank flusher. Take a look at it in the light.
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 10-14-2012, 09:27 PM   #5
2011 23' International
clovis , California
Tank flush hook up. Been there done that. Just be grateful it didnt overflow through your shower and onto your floor!
jgerardi is offline   Reply With Quote
Old 10-15-2012, 12:34 AM   #6
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
It's a real shame that dealers don't go through the unit and show the new owners how things work. Just sine here and it's yours. Good luck and thanks for the business.
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
RUMSHIP is offline   Reply With Quote
Old 10-15-2012, 04:37 AM   #7
m.hony's Avatar
2013 30' Classic
The dealer did do a walk through. I am hooked up to the city water. The Airstream guy showed me everything in that little compartment. I know the black tank flush is a white hookup on the left. There is a brass spigot with a red handle in the middle I assume for hooking up another hose to wash your feet, clean fish, etc. on the right to the side is the city water hookup with a short piece of hose to dangle out of a hole in the bottom of the compartment to hook up to city water. It is the grey water tank that is filling...or how is it labeled? Auxiliary holding tank? I think I am correct on this. There has to be a valve somewhere inside the trailer or a defective part. I did have the dealer install a t fitting for winterizing the trailer. That should have nothing to do with it. There is a white plastic valve by the water heater that I do not understand. It looks like the water would travel the same way regardless of the position of the valve. Help!
It did! I had told my wife before we left that she had too many towels. We used every single one to mop the floor.
Old 10-15-2012, 05:04 AM   #8
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The only way I can think of for city water to go directly to the grey tank is if the city water is connected to the termination cap at the dump valve, and the valve itself is left open.
Old 10-15-2012, 06:52 AM   #9
dznf0g's Avatar
Oswego , Illinois
You have it backwards. The white hookup on the left is the CITY WATER HOOKUP. The black hookup on the right is the BLACK TANK FLUSH HOOKUP. There is no gray tank flusher. Dealer told you WRONG! Main tank is black....Auxillary is gray.
There is no physical connection between the gray tank and supply plumbing except through the sink and shower drains. Additionaly, there is no connection between the black and gray tanks except if both release valves are open (then they would both fill equally while hooked up to the tank flusher) ORRRRRR, the black tank fills completely and fills up to the level in the vent stack and backflows into the gray tank. (IF this is the case...DON"T FLUSH THE TOILET...you'll have a nasty suprise.
I THINK your AS owner manual discusses thes labls and hookups.
-Rich-
Old 10-15-2012, 08:08 AM   #10
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
m.hony: suggestion, why don't you give the dealership a call this morning and double check your connection and valve locations with them. Airstream should maybe consider actually labeling all connections and valves. It might just help stop some of the confusion new owners have.
MICHAEL
Old 10-15-2012, 09:28 AM   #11
dznf0g's Avatar
Oswego , Illinois
Here is a pic of the hookups. On the left is the white city water hookup. It says "City Water" molded in the plastic flange. The Black tank flusher is around the corner and is black in color.
Here is a pic of the valves. Unless they have your labels on reversed, the Main (black tank) is on the left. The Gray tank (Auxiliary is on the right.)
Here is a pic of the Black tank label (Left one)
Here is a pic of the Gray tank label (right one)
-Rich-
Old 10-15-2012, 09:31 AM   #12
dznf0g's Avatar
Oswego , Illinois
Up through the toilet??????
-Rich-
Old 10-15-2012, 11:24 AM   #13
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 36
M.Honey Please listen...
This is important.
You have connected your water to the "Main Tank" flush. just as dznfog is trying to tell you.
The fresh-water connection is the female connector with the white plug, the "white hook-up on the left" as you call it.
Please quit insisting that the dealer gave you correct information.
Some dealers don't know squat.
You must not use that hose for fresh water. It is now contaminated with fecal matter.
Your health and the health of your family depends on listening to what we are trying to tell you.
Ken L
1966 Tradewind 24
2018 GMC Yukon XL Denali
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 10-15-2012, 11:42 AM   #14
ddruker's Avatar
2000 27' Safari
Palo Alto , California
I second all the above.
Before you do anything else, dump both of your waste tanks. You will have a disaster on your hands if you overflow your holding tanks by screwing around with this - the only place excess water can go is up through your shower drain and out on your bathroom floor.
Then go out and buy a new white fresh water hose. You can buy them at any home / garden center, walmart etc. Only get the white hose.
And from now on, only connect the white fresh water hose to the white city water inlet on your trailer.
The white fitting is colored that way to remind you of cleanliness - nice clean fresh water. Same goes with the hose.
The other fittings are black for a reason - as in black like poo.
- Dan
1999 27' Safari + 2011 Mercedes GL 350 Turbo-diesel
ddruker is offline   Reply With Quote
