Old 03-15-2014, 06:31 AM   #29
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Oh, and those valves are a vast improvement over the previous model toilet, which is no longer made. THAT valve was placed, then the toilet was cast around it. When it breaks, you replace the toilet.
Old 03-15-2014, 06:34 AM   #30
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Yeah! The valve is free! Thank goodness for carrying way too many tools in my trailer...
It appears that the freeze/fail occurred where the threaded part for the city water inlet is glued in to the housing.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:35 AM   #31
m.hony's Avatar
2013 30' Classic
There is a very, very small amount of lubricant on the button/plunger that resembles petroleum jelly?
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:40 AM   #32
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Yes, I used Teflon lube but you could use petroleum jelly or even KY....
Larry
lsbrodsky is offline   Reply With Quote
Old 03-15-2014, 06:41 AM   #33
m.hony's Avatar
2013 30' Classic
Lesson learned:
Always run pink through it.
Pink don't never fail me...
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:42 AM   #34
m.hony's Avatar
2013 30' Classic
I will have to purchase whatever lubricant, and Vasoline is cheap...
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:48 AM   #35
m.hony's Avatar
2013 30' Classic
Looking through my wife's cosmetics I found nothing.
Wondering if Neosporin, triple antibiotic ointment, athlete's foot cream, Vick's VapoRub, or anti-fungal cream would work...
After all, aren't all those products basically medicine suspended in petroleum jelly?
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:51 AM   #36
m.hony's Avatar
2013 30' Classic
Also wondering if I can apply super glue to the leaking part and fix it instead of a 160 mile trip to get the part...
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:51 AM   #37
lsbrodsky's Avatar
You do not want it to be water soluble so use the one that really does not wash off your fingers or toes.
Larry
Old 03-15-2014, 06:52 AM   #38
m.hony's Avatar
2013 30' Classic
You know...
If I make that long trip I will get 2 valves...
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:54 AM   #39
lsbrodsky's Avatar
No super glue, mine failed the same way. The valve body cracked along the seams. That is under full water pressure anytime the pump is on or city water is connected. You would need to break the body in two pieces, then glue and clamp, assuming you were able to break it in half along the broken seams.
Old 03-15-2014, 06:54 AM   #40
m.hony's Avatar
2013 30' Classic
Super glue won't do no good if it is busted on the inside where I can't see...
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:56 AM   #41
m.hony's Avatar
2013 30' Classic
Will definitely call Southaven RV to ensure they have the part before making the long journey...
Too bad big box stores don't have Dometic commode parts...
TAC #MS-10
Airforums #70955
Old 03-15-2014, 07:37 AM   #42
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Originally Posted by m.hony View Post
....instead of a 160 mile trip to get the part
hmm,
UPS and Priority Mail - the great equalizers of distance! and, often less expensive than gasoline or diesel.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 07:34 PM
Goodyear Marathon ST225/75R15 Failure Steve & Mary Tires 148 10-16-2014 07:40 AM
Winterizing pump siphon on 2013 27FB? Hubb Winterizing, Storage, Carports & Covers 3 02-06-2014 07:20 AM
Winterizing Question from a First-Timer tdmaymac 2009-2015 Flying Cloud 17 12-25-2012 11:47 AM
Frame Failure dmm9623 Repairing/Replacing Floor &/or Frame 9 08-12-2011 10:03 AM
