Old 03-14-2014, 08:25 PM   #15
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
The replacement valve comes with a conventional hose clamp so no pex stuff is needed to replace the flush valve. The line with the OEM crimped ring is the vacuum breaker line. Instruction sheet comes with the new valve and it takes about 15 minutes to replace.
Sent from my Nexus 7 using Airstream Forums mobile app
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 03-14-2014, 09:45 PM   #16
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Now if Southaven RV has the part...
I can save the day by going to the Harley shop and going to see the granddaughter.
It looks like that valve just snaps in. To remove the broken one it looks like I have to press in on 2 tabs, one at the bottom and one at the bottom.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-14-2014, 11:12 PM   #17
mefly2's Avatar
2015 25' FB Eddie Bauer
Sorry to hear that it gets so cold where you are. WE expect it up here and if it is any consolation our new AS (winterized by the factory / dealer and with stickers advising such) had a frozen flush valve, too. Easy fix, however.
Old 03-15-2014, 04:08 AM   #18
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Yes, that is exactly the valve I was talking about. Designed to fail in a freeze unless you blow it out or pump pink through it. Easily available on the internet, even Amazon, but your local RV place might have it. Total repair time for in and out is about 15 minutes after you scope out what to do.
Larry
lsbrodsky is offline   Reply With Quote
Old 03-15-2014, 05:36 AM   #19
m.hony's Avatar
2013 30' Classic
I thought I had blown it out.
Next winter I will either disconnect it or run pink through it.
We have never had as long and cold a winter as this.
On the chance that I am able to procure the valve, how is the old removed.
I'm getting tired of going to the bath house to pee.
I guess I could use the commode and flush with a pot of water, but that's about as much trouble as walking to the bath house...
TAC #MS-10
Airforums #70955
Old 03-15-2014, 05:48 AM   #20
lsbrodsky's Avatar
On the back there are one or two screws holding it in. Then the valve body has two prongs, top and bottom, that fit in slots on the toilet. You have to push one of those prongs towards the valve body with a screwdriver while pulling outward on the valve. It just pops out. To put the new one in, you just push it in place and reinstall the screws. My valve had some Teflon grease on the plunger so I greased the new one.
Larry
Old 03-15-2014, 05:55 AM   #21
Gainesville , Florida
Pink stuff good.,! Never failed me. Jim
Old 03-15-2014, 06:08 AM   #22
m.hony's Avatar
2013 30' Classic
I see no screws- only tabs top and bottom.
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:16 AM   #23
m.hony's Avatar
2013 30' Classic
Here is the back of the valve.Click image for larger version
Name:	ImageUploadedByAirstream Forums1394885763.543873.jpg
ID:	207487 [{\rtf1\ansi\ansicpg1252
{\fonttbl\f0\fnil\fcharset0 .HelveticaNeueInterface-M3;}
{\colortbl;\red255\green255\blue255;\red0\green0\b lue0;}
\deftab720
\pard\pardeftab720\partightenfactor0
\f0\fs34 \cf2 \expnd0\expndtw0\kerning0
\outl0\strokewidth0 \strokec2 \
}ATTACH]207486[/ATTACH]v
Name:	ImageUploadedByAirstream Forums1394885722.009746.jpg
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:17 AM   #24
m.hony's Avatar
2013 30' Classic
How do I get that metal band off of the PEX? Pliers? Screwdriver?
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:26 AM   #25
m.hony's Avatar
2013 30' Classic
OK. Got the valve out. I see there woulda coulda been some screws. I just didn't have any screws. Now to get that metal band off of the PEX and free the broken valve...
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:27 AM   #26
crisen's Avatar
Fairbanks , Alaska
All of the installations don't use the screws. To remove the band I used pliers at the crimp and twisted back and forth a couple times. This loosened the ring enough for it to slide up up the hose then pull the hose off the valve.
Rick
Old 03-15-2014, 06:29 AM   #27
m.hony's Avatar
2013 30' Classic
10-4. I was just wondering if they make a PEX "un-crimping" tool...
TAC #MS-10
Airforums #70955
Old 03-15-2014, 06:30 AM   #28
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Dremel tool with a cutoff wheel. It should be small enough to get behind the toilet to cut the ring off.
If you don't have a Dremel tool, this is the perfect excuse, err, reason to get one. They can be very versatile.
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 07:34 PM
Goodyear Marathon ST225/75R15 Failure Steve & Mary Tires 148 10-16-2014 07:40 AM
Winterizing pump siphon on 2013 27FB? Hubb Winterizing, Storage, Carports & Covers 3 02-06-2014 07:20 AM
Winterizing Question from a First-Timer tdmaymac 2009-2015 Flying Cloud 17 12-25-2012 11:47 AM
Frame Failure dmm9623 Repairing/Replacing Floor &/or Frame 9 08-12-2011 10:03 AM
