Old 04-20-2015, 02:20 PM   #1
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Missing Vent Cap. Causing Leak?
The round cap on my vent has disappeared. I noticed I have a leak on that side, could that be caused by the missing cap?
Next question, where can I get a new vent?
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 04-20-2015, 03:28 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
What vent do you have that has a round cover? The skylights are square, the frig is elongated, the sewer vent are not caped.
If you mean the black plastic shower fan cover yes that could cause a leak and that leak may show several feet away from the vent. There is a para pit around the fan opening that has a small drain hole on the lower edge. If that hole is clogged it can cause water to back up and flow into the body.
Mine showed up in the partition on the far side of the frig. several feet away, when I drilled a hole to mound something. The partition was wet inside.
2004 Excursion 4x4
Old 04-20-2015, 03:30 PM   #3
Soyboy's Avatar
1999 28' Excella
Images: 44
I'm sorry, I should have been more specific, it's the vent for the waste tanks.
1999 28' Safari
TAC MD-6
AIR 4534
Old 04-20-2015, 03:50 PM   #4
Soyboy's Avatar
1999 28' Excella
Images: 44
I looked again, the number was covered in caulk. It's a Ventline V 2049-1 for a 1 1/2 " pipe. Even though only the cap is missing. I need to replace the whole thing as I noticed the base has a crack in it.
1999 28' Safari
TAC MD-6
AIR 4534
Old 04-20-2015, 04:24 PM   #5
daveswenson's Avatar
2012 28' International
Issaquah , Washington
This might be what you're looking for.
http://www.amazon.com/360-Siphon-RV-...vent+cover+360
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 04-21-2015, 09:40 AM   #6
Soyboy's Avatar
1999 28' Excella
Images: 44
Thanks Dave. Actually this is the one I needed, and ordered for my '99.
1999 28' Safari
TAC MD-6
AIR 4534
Old 04-21-2015, 09:58 AM   #7
aftermath's Avatar
Spokane , Washington
A missing cap would allow rain/snow into the pipe but that just goes to the black tank so, no, I don't think this would cause your leak.
A cracked base on the other hand might very well be the culprit.
aftermath is offline   Reply With Quote
Is my spare tire causing frame sag? pauly g Repairing/Replacing Floor &/or Frame 12 12-11-2007 12:01 AM
Brake failure causing major damage? davidz71 Brakes & Brake Controllers 12 11-02-2007 03:24 PM
Tire blew causing trailer damage RUSSELL Tires 1 11-02-2007 03:20 PM
Tires Causing Sway? Pick Tires 14 12-03-2006 04:38 PM
Semi Truck Problems - causing sway or fish tailing woodedareas Hitches, Couplers & Balls 25 11-26-2006 08:51 PM
