Old 04-03-2005, 09:36 PM   #1
1992 34' Limited
Falls Church , Virginia
Missing H2O cutoffs????
Hello all -
Hunting for the H2O cutoffs/ drains on my '92 34footer with center bath, rear twins.
Found the under bed one in the rear, under the bed. According to the manual, there are 3 more under the micro cabinet, but found them in the triple wardrobe floor. Actually only found 2 - not the 3 that the manual says.
The 2 in the wardrobe are 90degree type ball valves. Crawled under the wheels and found another white cutoff ( handle turns and turns) outside the access panel. Is this my 3rd cutoff/drain?
The access panel cover is missing as I can see the ground out of the wardrobe. Can I cover this with handy material or is there an specific reason that it needs to be aluminum - other than the purist thing?
Also, noticed a dent in the underbelly pan around the tank (grey water???) that is between the axles. Looks like someone backed into something as the cover is creased and pushed in about 2 inches. There is another tank more rearward ( black water??) that looks unmolested as far as damage.
The digital camera is on the fritz right now - will get it back on line soonest. Will post photos to hopefully help you, to help me. Yikes, hope I have that right!?!
Thanks to everyone that his been a great help so far. Spent last night in SilverToy. LOVED IT!
Ciao
Axel
SilverToy is offline   Reply With Quote
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Missing Electrical Outlets gklott 2001 - 2005 Classic 2 04-21-2004 01:03 PM
Aluminum underbelly missing Joe C 2002 - 2005 International 10 11-10-2002 09:41 PM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 04:16 PM
'66 Safari - step and window guard parts? Gordon 1966 - 1968 Safari 1 04-20-2002 11:16 AM
