Old 06-14-2012, 06:47 PM   #1
1989 29' Excella
Tyrone , Georgia
Midway through pex.. Any tricks to get lines over to shower under floor?
I currently have the shower tub removed and can see the two lines that run from the area under the microwave across to back corner of the shower. However, the lines do not move freely so my plan of connecting the pb to new pex and pulling through the new line no longer sounds like a good idea.
Any tips?
mikeandnora is offline   Reply With Quote
Old 06-14-2012, 07:06 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
They probably have some hose clamps holding them in place.. You could change what you can get to. Shark Bites work well for connecting pex to copper or for use in tight places. Other than that you would have to try and find where it goes.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-14-2012, 08:38 PM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I once owned an 89 excella.
The existing pipes run across the top of the fresh water tank and are probably being squeezed by the tank. You will likely have to drop the tank down a few inches in order to get the pex shoved through.
If the poly lines are still good consider a polybutylene pex adapter fitting on each end.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-15-2012, 05:34 AM   #4
1989 29' Excella
Tyrone , Georgia
Thanks guys!
