Old 03-11-2019, 02:31 PM   #1
1964 26' Overlander
Ames , Iowa
Major Newbie Questions: Stationary Trailer
I have a Overlander 1964, my dream was to have it site on my property as a guest house. Can anyone please answer me a few questions...
1. Can the bathroom be hooked up with our existing water and septic system? Is it recommended or not? Any links with more info? I'm not even sure the verbiage for searching the internet with more information.
2. Is a "outhouse" concept better?
I want to set up a set it and forget it system, but winterizing I could do. Any thoughts?
lesliehall is offline   Reply With Quote
Old 03-12-2019, 07:24 AM   #2
Magnet18's Avatar
Churubusco , Indiana
Hooked up to water and septic, certainly possible. Lots of people put in a 4" sewer connection for cleaning out their tanks when they get home, same idea.
You can install a garden hose spigot hooked up to your homes softened water for supply.
Winter depends on where you live, but water freezes and these aren't insulated like a house, so making this "set it and forget it" in Florida is easy, but for a Maine winter it becomes a question of how many zeros you're willing to put into it.
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 03-12-2019, 07:35 AM   #3
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
As far as being able to forget about it, you may for a while....The black tank does not drain as thoughoughly as a sewer pipe would and eventually will pile up, so to speak.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 03-12-2019, 08:02 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Unless you remove the black tank and install a household toilet, you will need to keep the black tank valve closed and dump into your sewer cleanout as necessary. The black tank should not be allowed to dry out as this creates problems.
Yes, you can remained hooked up to your water system via a garden hose as you would at a campground. In freezing weather it would be better to unhook the garden hose and use tank water during those periods.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Living permanently in a stationary Airstream LindsayStove Full-Timing 66 11-12-2016 09:04 PM
Would an older Airstream be okay for me? Full time, stationary, non park alexj Full-Timing, Winter Living & Workamping 49 09-24-2015 11:45 AM
Black water holding tank changes for using trailer as stationary home/external septic bol-gordon All Argosy Trailers 3 05-20-2009 07:34 AM
Fulltiming: stationary or mobile? (Poll) clecogirl Full-Timing 11 02-24-2007 03:31 PM
If Airstreams were stationary... at_wanderer Off Topic Forum 15 11-14-2006 11:09 AM
