Old 09-15-2015, 10:50 PM   #1
2006 25' Safari SS SE
Reno , Nevada
Low Water Pressure At Sinks
Hi folks,
First time here, hoping for a suggestion or two. 2006 Safari, both faucets at sinks run ever so slowly; this is a new situation. Shower and toilet water pressure is fine. Same problem with city water and using water pump. I looked for a filter, but did not find anything ... any thoughts?
Dave in Reno Nevada
ddrinks is offline   Reply With Quote
Old 09-15-2015, 10:57 PM   #2
1974 Argosy 20
Kooskia , Idaho
Probably the sink faucet aerator screens are both plugged. Take them off (they just unscrew) an you will find them covered with white sediment most likely from the water heater. Clean and replace, you will be good.
Old 09-15-2015, 10:57 PM   #3
1979 23' Safari
Wayland , New York
Check the faucet outlet strainers. The round things the water comes out of on the faucets, they screw in and have screens and often flow limiters that can get clogged by dirt. Unscrew and check for debris. While they're off run some water to flush any dirt out of there before putting them back on. Common problem.
Old 09-16-2015, 12:09 PM   #4
Reno , Nevada
Your suggestion worked ... thank you.
Dave
Old 09-16-2015, 12:10 PM   #5
Reno , Nevada
It worked ... thank you!
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Very low water pressure for hot water from pump barrettjl Water Heaters, Filters & Pumps 21 10-27-2014 07:41 AM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Help: Shower and Toilet work; No water pressure in sinks donshade Fresh Water Systems 4 06-13-2009 06:16 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
