Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 08-25-2005, 02:43 PM   #1
eddo
Profile:
Low spot in pipes
I have been checking out my water system and found a leak in a low spot in the pipes. After fixing the leak how does one drain the whole water system even the low spots where it might hold some water captive for our common enemy Mr. Freez.. I'm a newbe with Airstreams. Regards, Eddo
eddo is offline   Reply With Quote
Old 08-25-2005, 02:59 PM   #2
tinman7
tinman7's Avatar
Profile:  1976 27' Overlander
Arlington , Massachusetts
Images: 13
At the end of the season I blow out pipes with air and then pump in antifreeze. The water heater will need to be drained and a bypass should be installed so as not to fill with antifreeze. There are lots of post on the forum about winterising.
tinman7 is offline   Reply With Quote
Old 08-25-2005, 05:30 PM   #3
74Argosy24MH
Profile:  LOST , Hawaii
Arizona-freeze? I didn't think you would even know what that was. Why not just make it a drain point?
74Argosy24MH is offline   Reply With Quote
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 06:23 AM
low drain points Raptorrider2001 1999 Safari 18 12-12-2002 04:17 PM
Low Voltage Problem kellyw Electrical - Systems, Generators, Batteries & Solar 3 10-23-2002 06:35 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
